Calculating vortex cores of relative velocities |
September 19, 2013, 10:19 |
Rep Power: 16 |
Hi, I want to use Tecplot to calculate the vortex core behind a wind turbine blade. I'm using a moving reference frame in Fluent to simulate the flow around the turbine blade. When I read the resulting case and data files into Tecplot I first convert the absolute velocities into relative velocities and then apply the new the new variables:
> Data > Alter > Specify Equations: {v_rel_x}=... {v_rel_y}=... {v_rel_z}=... > Analyze > Field Variables: U={v_rel_x} V={v_rel_y} Z={v_rel_z} But when I calculate the vortex core Tecplot always calculates it using the absolute velocities and not the relative ones that I specified. Does anyone have an idea of how I can use the velocities that I specified?? Thank you, Dorit |
December 17, 2015, 05:23 |
vortex core
浅笑221
hello,i have found the same problem that the vortex core is invariant even we change the filed variable,have you found a method?please tell me,thank you!
post procesing, relative velocity, tecplot, vortex |
how to get relative velocities in a rotating frame of reference? | alkochevsky | OpenFOAM Post-Processing | 14 | May 31, 2017 06:05 |
Presenation of vortex strength and velocity concept? | fruitkiwi | Main CFD Forum | 0 | September 26, 2012 22:08 |
Vortex Lattice Method: Calculating lift using circulation from vortex ring elements | black&gold | Main CFD Forum | 11 | June 26, 2011 23:51 |
UDF for vortex cores | Grace | Fluent UDF and Scheme Programming | 0 | March 18, 2010 05:19 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
