[ICEM] Meshing a skewed object at low solidity |
June 17, 2012, 14:13 |
KB
1)I am trying to mesh a windmill blade, with low solidity(i.e. spacing smaller than the width of the chord. ) at a pitch angle of about 22. The trailing edge is skewed I realise using blocking for the mesh will not represent the fluid at the trailing edge very well.The mesh also has to be periodic at the top and bottom boundaries. I have a sample of the preliminary mesh attached. Can anyone advise on the best approach to this.
Thank you |
June 17, 2012, 18:00 |
Khayyamian
I recommend to use an O-grod around the blade, this causes to mange the leading and trailing edge more precisely.
see this for example http://www.cfd-online.com/Forums/ans...e-meshing.html |
June 17, 2012, 21:46 |
KB
Thanks, I actually used o-grid when I had high solidity or when the airfoil was treated as an isolated one. There was no problem generating the mesh and capturing the flow. However, when the spacing becomes smaller and it is at a pitch angle other than zero it became difficult to use o-grid.Find attached the a surface mesh of the problem, the only thing in this case is i could not get periodicity.
[ANSYS Meshing] How to get rid of skewed elements while meshing a pipe with many interfacing surfaces | everdimension | ANSYS Meshing & Geometry | 12 | September 15, 2016 18:54 |
problem meshing with low y+ | cesco | FLUENT | 8 | February 23, 2009 05:12 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 11:09 |
