[ICEM] merge 2D domain tetra hexa
Old   June 28, 2012, 14:46
Default merge 2D domain tetra hexa
djfanf is on a distinguished road
hy everyone,
I try to do an hybrid mesh for the following two part, I started to mesh the part around the circle with a blocking strategy and converted the mesh to an unstructured. After that I gave the surface and curve mesh setup for the "circle part" and create an unstructured tetra mesh, I know there is a function that allowed to merge meshes but only for a 3D mesh, it does not work in my case...
I am quite sure there is also his possibility for a 2D mesh but I don't find it.. Anyone have an idea how to get a smooth transition between my two meshes ? Thanks !
djfanf is offline   Reply With Quote
Old   June 28, 2012, 17:12
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
it should be two regions with the same name. then go to edit mesh -» merge meshes and select that region then click on apply
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   June 29, 2012, 11:38
thanks for your reply but it does not work at all...
I have this message "This function only works with volume meshes"
I think this function is only for 3D mesh Anyone esle have an idea ?
Old   June 29, 2012, 15:36
diamondx's Avatar
Ghazlani M. Ali
hmm it's true that i never tried in 2d. can you share your project ?
Regards,
Ali
Old   July 1, 2012, 08:44
yes I can, no secret project ;-)
here are the files you need, it's a rar compressed file, so juste rename the file extension to .rar and you'll be able to open it !
Old   July 2, 2012, 11:01
diamondx's Avatar
Ghazlani M. Ali
i just look at your mesh ! you were right it only works with the volume mesh. As you dont have a big number of elements, i suggest you try merge interactive. What you will do is selecting the nodes individually with your mouse, and you will merge them. i tried in a couples of nodes and it works. did you try it ??
Regards,
Ali
Old   July 2, 2012, 14:19
thanks for your answer ! I 'm just wondering why there is no similar function as merge meshes for 2D geometry...
Well I will try to do it manually like you said or will just do the same in 3D so that I would be able to use this function :-)
calculation of additional variable in multiple domain cosine CFX 12 April 24, 2016 12:51
Vertical Axis Wind Turbine Rotating Domain Problems TWaung CFX 4 May 1, 2012 03:14
tetra hexa mesh hamid1 FLUENT 5 April 12, 2012 11:23
CFX domain comparison Kiat110616 CFX 4 April 3, 2011 22:43
rotating domain in rotating domain, different axis Robert Stringer CFX 3 December 4, 2006 07:04
