June 28, 2012, 14:46 |
merge 2D domain tetra hexa
Rep Power: 14 |
hy everyone,
I try to do an hybrid mesh for the following two part, I started to mesh the part around the circle with a blocking strategy and converted the mesh to an unstructured. After that I gave the surface and curve mesh setup for the "circle part" and create an unstructured tetra mesh, I know there is a function that allowed to merge meshes but only for a 3D mesh, it does not work in my case... I am quite sure there is also his possibility for a 2D mesh but I don't find it.. Anyone have an idea how to get a smooth transition between my two meshes ? Thanks ! |
June 29, 2012, 11:38 |
Rep Power: 14 |
thanks for your reply but it does not work at all...
I have this message "This function only works with volume meshes" I think this function is only for 3D mesh Anyone esle have an idea ? |
July 1, 2012, 08:44 |
Rep Power: 14 |
yes I can, no secret project ;-)
here are the files you need, it's a rar compressed file, so juste rename the file extension to .rar and you'll be able to open it ! |
July 2, 2012, 11:01 |
Ghazlani M. Ali
Rep Power: 29 |
i just look at your mesh ! you were right it only works with the volume mesh. As you dont have a big number of elements, i suggest you try merge interactive. What you will do is selecting the nodes individually with your mouse, and you will merge them. i tried in a couples of nodes and it works. did you try it ??
July 2, 2012, 14:19 |
Rep Power: 14 |
thanks for your answer ! I 'm just wondering why there is no similar function as merge meshes for 2D geometry...
Well I will try to do it manually like you said or will just do the same in 3D so that I would be able to use this function :-) |
calculation of additional variable in multiple domain | cosine | CFX | 12 | April 24, 2016 12:51 |
Vertical Axis Wind Turbine Rotating Domain Problems | TWaung | CFX | 4 | May 1, 2012 03:14 |
tetra hexa mesh | hamid1 | FLUENT | 5 | April 12, 2012 11:23 |
CFX domain comparison | Kiat110616 | CFX | 4 | April 3, 2011 22:43 |
rotating domain in rotating domain, different axis | Robert Stringer | CFX | 3 | December 4, 2006 07:04 |
