[ANSYS Meshing] Question about mesh generation for a wedge |
July 8, 2012, 11:29 |
lnk
Rep Power: 15 |
I'd like to generate high quality mesh for a wedge by ICEM? (You can see it at the attachment. The flow is from left to bottom.) May I ask what kind of mesh would you recommend me to generate? Thanks! I'm looking forward to your answer. lnk |
July 8, 2012, 12:00 |
#3 | |
lnk
Rep Power: 15 |
lnk |
July 8, 2012, 16:14 |
lnk
Rep Power: 15 |
Thank you very much for your answer. I tried to make the meshes again but still not able not generate high quality mesh as you did. Here is my mesh. You can see I always have problem at the frontal part (edge part) of the wedge . May I ask you how to solve this problem? Best regards, lnk |
July 9, 2012, 00:59 |
I guess in ur case angle is very sharp. You can use wedge elements (prisms) instead of hex for very sharp angle (Simon suggested in one of the posts on this forum) to control the quality.
July 9, 2012, 01:42 |
Alex
Rep Power: 47 |
There is still an importand difference between your blocking and the one suggested by Far.
Merge the 2 blocks at the sharp edge just like Far did. |
July 9, 2012, 01:59 |
#9 |
@flotus1 I didn't observe this difference.
@Ink : You must use Quarter ogrid or Y-block Procedure is explained in detail here http://www.cfd-online.com/Forums/ans...tices-why.html http://www.cfd-online.com/Forums/ans...here-cube.html |
July 9, 2012, 17:13 |
#10 | |
lnk
Rep Power: 15 |
I think Flotus is correct. There is a significant difference between our meshes. I learnt your link but still not able to generate meshes like you. May I ask you to show your block? Best regards and many thanks, lnk |
July 9, 2012, 19:04 |
#11 |
Ghazlani M. Ali
Rep Power: 29 |
i'm making an ygrid in this video:
http://www.youtube.com/watch?v=nuiRkZqaEz4 start watching after 3:05 s |
July 10, 2012, 06:48 |
#12 | |
lnk
Rep Power: 15 |
[blockMesh] Problems in creating a wedge type mesh | Joscha | OpenFOAM Meshing & Mesh Conversion | 28 | August 3, 2019 07:59 |
ISAAC code mesh generation | morteza08 | Main CFD Forum | 0 | June 15, 2012 09:26 |
Non-conformal mesh question | Jason | FLUENT | 1 | January 12, 2005 16:17 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
3-d elliptic generation mesh | Gang Sun | Main CFD Forum | 5 | September 16, 1998 00:24 |
