[GAMBIT] Gambit Start Up error .... HELP PLZ!
Old   July 11, 2012, 01:29
Lightbulb Gambit Start Up error .... HELP PLZ!
Abhya is on a distinguished road
Hi everyone...Im new to this Forum ..plz help me with the follwing issue in GAMBIT.
When i Satrt an already saved sesion in GAMBIT I first got the follwing error:
"This product has the following patch(es) applied:
patch_2230_1
You can find more information about the patch(es) in the
respective text file(s) located at:
C:\Fluent.Inc\gambit2.2.30.
ERROR: IDENTIFIER "basgeom" CURRENTLY OPEN
usage: C:\Fluent.Inc\gambit2.2.30\ntx86\\gambit.exe
-def(aultsfile) file
-dev(ice) X11|XWIN|OPEN(GL)|GL|XGL|SBX|STAR(BASE)
-doc(umentation)
-geom(etry) WIDTHxHEIGHT+X+Y
-font xs|s|l|xl
-help
-id name
-inp(utfile) file (implies batch run and no gui)
-init(file) file (a journal file to run at startup of gui mode)
-new|-old
-proe proe_command
-res(torejournal) file
After searching here I found that deleting the temp dirs and .lok files helps ...so I did that but then I got the following error ..
this time gambit opens but it doesn't open the saved session .. it opens a new session .. th eerror mssg. is :
"You can find more information about the patch(es) in the
OPENGL_DEVICE_DRIVER not supported
Defaulting to X_DEVICE_DRIVER with standard visual
Another IMP Thing I thought I should mention :
I first saved the session on gambit 2.3.16 And then tried to open it in 2.2.30 ..
I'm unable to solve this issue even after searching so posted here..plz help me
Thanks in Advance
Good Day
Abhya is offline   Reply With Quote
Old   July 11, 2012, 02:49
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
opening a dbs file saved with 2.3.16 with an older version of gambit won't work
And your previous issue came because you had .lok file in your working directory (tyipical gambit issue)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   July 12, 2012, 00:40
hey thanks...I insatlled the same version on both PCs and opened it thru the same version ..its fine now....
[GAMBIT] Canīt start GAMBIT zalho ANSYS Meshing & Geometry 18 April 8, 2019 01:05
Gambit Startup Window Jay Shim FLUENT 2 February 12, 2015 14:05
I canīt start Gambit 2.4.6 windows 7 Oneearthquake ANSYS Meshing & Geometry 3 April 20, 2012 09:56
[GAMBIT] Gambit start win vista? ferranpm ANSYS Meshing & Geometry 1 June 8, 2009 16:23
Lets start the public domain CFD-Project! Heinz Wilkening Main CFD Forum 3 March 11, 1999 22:55
