[ICEM] Question about fluid domain dividing
Old   July 19, 2012, 14:19
Question Question about fluid domain dividing
lnk
lnk
lnk is on a distinguished road
At CFX, when we define a fluid domain we will need to choose the location. At my work, the locations always contain more that I want. I know that's because I extended instead of creating separate blocks when I designed mesh for them. But since my geometry is complex, the work is too large that I really don't want to go back to do them again. May I ask is there anyway to separate them so that I can define the fluid domain as I wish? (If CFX has this function, it's also good.)
And if I divide the mesh too much (means I should've extended blocks but I created them when I generate the mesh for complex geometry), is it okay to choose several locations when I define fluid domain? The nodes at the interface still match with each other. Will there be any difference from what if I extended the block?
Best regards and many thanks,
lnk
lnk is offline   Reply With Quote
Radiation at interface between fluid and porous domain Hitch8 CFX 19 April 20, 2015 06:24
Different diffusivity for additional variable in Fluid and porous domain ftab CFX 4 June 27, 2012 13:03
ERROR #001100279 for a Rotating Fluid Domain Fonzie CFX 3 August 24, 2010 19:42
Soft for fluid domain extraction Luk Main CFD Forum 0 February 11, 2009 03:58
CFX Fluid Domain Movement greg CFX 1 March 25, 2007 08:08
