[ICEM] Error messgae
Old   July 29, 2012, 15:18
Exclamation Error messgae
Anna Tian's Avatar
Meimei Wang
Anna Tian is on a distinguished road
Hi everyone,
When I'm outputing the mesh at ICEM, I get error message like this
'Error
Running ICEM CFD CFX5 Interface Vers: 14.0.0
Warning: duplicate shell element found: 536& 516
Wrong element type (el_type=-1)
Error exit in local_face (iel=380)
child process exited abormally
What does that mean?
Best regards,
Meimei
Anna Tian is offline   Reply With Quote
Old   July 30, 2012, 11:57
Ananthakrishnan.A.S
Ananthakrishnan is on a distinguished road
Send a message via Skype™ to Ananthakrishnan
i think you have created a unstructured mesh. If yes, then you have not "checked" the mesh. If not do not read further because it might not be pertinent to your problem. In this case try to give more info about your mesh..
In case of unstructured mesh there might be certain kind of elements in the mesh which are not compatible with many processors such as CFX and Fluent. Some might handle certain kind of mesh orientations which others do not.
One of this is the duplicate element which is not supported by CFX. So what you need to do is run the option "check mesh" under edit mesh. It will display the possible problematic mesh elements. If its just duplicate elements you can select the mesh part containing the duplicate elements and delete it. If not you have to trouble shoot step by step
Ananthakrishnan is offline   Reply With Quote
