[ICEM] Meshing a 3D airfoil using ICEM
Old   August 17, 2012, 03:41
Question Meshing a 3D airfoil using ICEM
Julian121 is on a distinguished road
I need to mesh a 3D airfoil using ICEM. I have created the geometry using ANSYS but I have never used ICEM before.
Could you tell me how I can mesh that using ICEM?
I would appreciate if you could help me.
Geometry link:
http://www.sendspace.com/file/pb9xdq
Julian121 is offline   Reply With Quote
Old   August 17, 2012, 04:18
nitin bansal
nitinbansal184 is on a distinguished road
Geometry link:
If you really wants to put your airfoil in ICEM then you need to airfoil coordinate file
Import these coordinate and join them by using spline..
Then make C-grid to do meshing task
nitinbansal184 is offline   Reply With Quote
Old   August 17, 2012, 11:31
cfd seeker is on a distinguished road
Geometry link:
http://www.cfd-online.com/Forums/ans...mesh-wing.html
this link is showing a thread in which detailed discussion about different blocking typologies is given
http://www.youtube.com/watch?v=mgjRT...ature=youtu.be
this video is tutorial for structured hexa meshing for wing
I hope both these things will help you alot
cfd seeker is offline   Reply With Quote
Old   August 17, 2012, 11:32
If you still require more after this I will be happy to help you
Old   August 17, 2012, 11:52
brijeshdubey11's Avatar
brijesh dubey
brijeshdubey11 is on a distinguished road
If you want to create a wing. then just import .dat file of airfoil co-ordinates. it will automatically create curves and similarly import another one and transform it in the z direction then make two lines one joining leading edge point of both while other at trailing edge. and then create surface. after that proceed to blocking.
brijeshdubey11 is offline   Reply With Quote
[ICEM] complex 2D meshing on ICEM kassab ANSYS Meshing & Geometry 26 April 14, 2014 21:02
[ANSYS Meshing] ICEM Meshing :specified nodes along curve did not appear syler3321 ANSYS Meshing & Geometry 3 June 13, 2012 15:45
[ICEM] 2d Aerofoil meshing in ansys ICEM syler3321 ANSYS Meshing & Geometry 2 February 3, 2012 01:59
[Other] Ansys meshing airfoil and / or compressor blades baw192 ANSYS Meshing & Geometry 8 September 23, 2011 00:43
ICEM meshing question gsbhatia89 ANSYS Meshing & Geometry 5 June 14, 2010 08:24
