[ICEM] Prism layering options
Old   October 7, 2013, 08:34
Default Prism layering options
siw
Stuart
siw will become famous soon enough
There's two parameters in ICEM which deals with how prism layers are built and treated in relation to the prism-to-tetra transition: Max Height Over Base (MHOB) and Prism Height Limit Factor (PHLF). It seems to me from reading the material and trying different meshes (so I know what they do) that the MHOB is only suitable to cap the layering of prisms if they are not floated, and instead all required layers are build one after another. Whereas, the PHLF is only suitable when floating the prisms to give a smooth prims-to-tetra transition.
Has anyone used both the MHOB and the PHLF at the same time and was it with floated or non-floated prisms? Also what about using only MHOB for floated prisms? Interested in finding out what others do.
siw is offline   Reply With Quote
Old   October 8, 2013, 13:10
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Floating the prisms is similar to using PHLF, except that you don't set the initial height (it gets calculated).
You can't really use MHOB and PHLF at the same time. Which ever ratio it hits first will prevent the other one from being reached.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Getting prism to inflate into mixed tet-hex meshes Joe CFX 16 October 10, 2011 07:06
ICEM Prism Layer transition between surface with prism layers and one without TWaung ANSYS Meshing & Geometry 2 October 12, 2009 14:56
Trimmer & prism layer peresah STAR-CCM+ 6 October 6, 2009 14:39
ICEM - Prism Tool Problem carpe85 CFX 0 February 10, 2009 12:25
Icemcfd: Preventing prism inflation collisions? Joe CFX 1 July 31, 2007 09:13
