[ICEM] Boundary Layer Thickness
Like Tree1Likes
  • 1 Post By siw
Old   September 12, 2012, 04:41
Default Boundary Layer Thickness
Joh
Joh
Joh is on a distinguished road
Dear all,
How can you assess if the boundaries are sufficiently big enough to deal with your flow? So for unstructured mesh, how do you know how many prism layers to use. I use 3, split them into 6 and then rearrage them with a ratio of 1.4 and it seems to work. But how confident can I be that this will give the right results?
Regards,
Joh
Joh is offline   Reply With Quote
Old   September 12, 2012, 08:27
siw
Stuart
siw will become famous soon enough
In answer to your question, you will need to conduct a simulation to see if the results are physically sensible/what you expect/match other sources of data. Only then can you know if the modelling of the boundary layer etc with your chosen generation of prisms was okay. If not you'll then have to make some mesh changes and repeat. Personally, I keep the expansion ratio to 1.2 or lower. Also, if using CFX (so I know it's in the manuals) but probably FLEUNT aswell it recommends 10 to 15 layers for RANS simulations and the y+ depending on the turbulence model and near wall treatment of choice.
siw is offline   Reply With Quote
Old   September 12, 2012, 09:34
Joh
Joh
Thanks, why do you keep the expansion ratio to 1.2 or lower?
What about for structured meshes, how do you know how far the O-ring has to be placed for laminar flow? Is it the same idea? Run the mesh and see if it gives a plausible solution?
Old   September 13, 2012, 08:37
siw
Stuart
1.2 is the default value in ANSYS Meshing and it is the recommended value I've found in various user manuals, reports etc. However, sometimes I use lower values, but not hgher values. Give it a try and see how/if your results are dependent upon the value.
Again for the O-grid question, you'll only know once you've tried some different lengths for your particular simulation and its effect. I find with mesh generation, you just have to make what you judge to be a reasonable mesh for your simulation (to as best a quality as you can get it) and then run the simulation and repeat from there as you think best.
PSYMN likes this.
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
Questions about Boundary Layer Thickness and Turbulence Models famerfamer STAR-CCM+ 3 July 12, 2012 09:47
Boundary Layer roughness/ low reynolds wall treatment Luigi_ STAR-CCM+ 1 March 14, 2012 08:40
Boundary layer thickness ghazanfarzahedi Main CFD Forum 2 July 28, 2009 23:43
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
