October 13, 2012, 12:30 |
odel the stirred tank in GAMBIT
Jamal Foroozesh
Hi dear friends
Im MSc student in material science. I want to model the stirred tank in GAMBIT for use sliding mesh in fluent. Can everybody any help me in creating it? thanks |
October 15, 2012, 01:32 |
Maxime Perelli
Rep Power: 41 |
if you give more informations, maybe would someone help you
In memory of my friend Hervé: CFD engineer & freerider |
October 15, 2012, 03:18 |
Jamal Foroozesh
pictures of my problem is below.
units in cm depth of groove: 3mm how I do model inner&outer zone for sliding mesh in my problem? thanks |
October 15, 2012, 03:30 |
Maxime Perelli
Rep Power: 41 |
is your sliding mesh relating to rotation of impeller?
I saw a domain with air. Does it mean you are also solving multiphase?
October 15, 2012, 03:34 |
Jamal Foroozesh
October 15, 2012, 03:44 |
Maxime Perelli
Rep Power: 41 |
ok
First, you need to split your domain. I talk now about multiphase: if the height of yoru domain is 26.5cm, then you create and move a plane and you split the volume for having 2 volumes in respect of your picture (height 21.5 & 5) You should be able to select either water volume, or air volume. Second, the sliding zone: for that you will create a cylinder with a radius 5,6 7 or waht you want (radius has to be greater thant max radius from impeller). Move the the cylinder in such way that it will be coaxial to the impeller. Split your water volume with the cylinder, and delete the cylinder. Check if you can select the impeller zone (rotor). If yes, copy this volume with any translation's vector. Delete the original impeller volume. Now you have an hollow in the water domain. Select the cylindric surface from stator domain, and define it as interface. Select the cylindric surface from rotor (copy), and define it as interface. Now move the rotor (copy) back , with opposite translation's vector. That's it..............
October 15, 2012, 03:53 |
#7 | |
Jamal Foroozesh
I contact with you, tonight tnx |
October 15, 2012, 07:34 |
Jamal Foroozesh
thanks
What is the size of the inner cylinder (sliding mesh zone)and the its exact location? |
October 15, 2012, 07:36 |
Maxime Perelli
Rep Power: 41 |
the radius is up to you, but the cylinder should englobe the impeller.
Cylinder's axis hast to be the same than impeller This split will generate the rotor zone
October 15, 2012, 07:47 |
Jamal Foroozesh
This is the new image:
October 15, 2012, 08:06 |
#11 |
Maxime Perelli
Rep Power: 41 |
yes; now copy your cylinder anywhere and apply interfaces.
In your case you will need to also apply interfaces on top and bottom from cylinder. And now I wonder if it would be more easy to extrude your cylinder in air-domain. Thus, you will also have sliding mesh in air-domain
October 15, 2012, 08:19 |
#12 |
Jamal Foroozesh
I need to define moving zone (zone and not boundary condition)?
If it is needed, where it should be defined? |
October 15, 2012, 08:22 |
#13 |
Maxime Perelli
Rep Power: 41 |
both: zone and boundary conditions
I would recommand you to start without multiphase. Then if your sliding mesh is successfull you can add complexity with multiphasis
October 15, 2012, 08:47 |
#14 | |
Jamal Foroozesh
How to be define the zones? |
October 15, 2012, 08:55 |
#15 |
Maxime Perelli
Rep Power: 41 |
as I said I would split your first zone (first picture) with the same plane (air-water), and then delete the air-domain (2nd picture) and also the rest of first zone.
That means only water. Before deleting, save as another name for being able to pick this dbs later. For the zone, you only need to define rotor as another fluid domain (say rotor). But the most important is interfaces. For that your both volumes (stator and rotor) has to be disconnected (as I previously described). To check if they are, try to move (not copy) the rotor anywhere. If it is successfull, then both volumes are disconnected
October 15, 2012, 15:03 |
#16 |
Jamal Foroozesh
Hi dear Max
are you sure that inner cylinder must be deleted? when I delete the inner cylinder, fluent shows below error: " Grid Check Domain Extents: x-coordinate: min (m) = -1.200000e+001, max (m) = 1.200000e+001 y-coordinate: min (m) = -1.199330e+001, max (m) = 1.199330e+001 z-coordinate: min (m) = 0.000000e+000, max (m) = 2.650000e+001 Volume statistics: minimum volume (m3): 3.673007e-003 maximum volume (m3): 9.045283e-001 total volume (m3): 1.159029e+004 Face area statistics: minimum face area (m2): 4.027711e-002 maximum face area (m2): 1.069187e+000 Checking number of nodes per cell. Checking number of faces per cell. Checking thread pointers. Checking number of cells per face. Checking face cells. Checking bridge faces. Checking right-handed cells. Checking face handedness. Checking face node order. Checking element type consistency. Checking boundary types: Checking face pairs. Checking periodic boundaries. Checking node count. Checking nosolve cell count. Checking nosolve face count. Checking face children. Checking cell children. WARNING: Unassigned interface zone detected for interface 6 WARNING: Unassigned interface zone detected for interface 7 Checking storage. Done. WARNING: Grid check failed." What do I have to do? |
October 16, 2012, 01:26 |
#17 |
Maxime Perelli
Rep Power: 41 |
basically you only delete the inner cylinder you used for the split.
The other inner cylinder (with impeller) is deleted BUT replaced by its own copy. So you are not suppose, at the end, having a hole at place of rotor. The warnings are ok since you didn t define the grid interfaces
October 16, 2012, 17:26 |
#18 |
Jamal Foroozesh
Dear Max
Do I need to subtract impeller volume from inner cylinder? thank you so much |
October 17, 2012, 00:47 |
#19 |
Maxime Perelli
Rep Power: 41 |
yes.
So in you case: *copy volume 3 (translaction vector (0 0 0)) --> it generates a volume 5 *unite volumes 2 & 3 *substract volume 2 with 1 *split volume 2 with 5 *delete impeller volume (6) --> here this volume should be deleted with substract tool, but I don't know why it is not the case *copy volume 5 with (0 0 50) --> it generates a volume 7 *delete volume 5 *assign all the interfaces on volume 2 & 7 *move volume 7 with (0 0 -50) That's it!
October 17, 2012, 02:30 |
#20 | |
Jamal Foroozesh
Meshing stirred tank with gambit. | boh_tea | FLUENT | 13 | March 29, 2013 13:29 |
model the stirred tank in GAMBIT | jamalf64 | FLUENT | 0 | October 13, 2012 12:24 |
Simulation of stirred tank using sliding mesh technique | aymneng | Main CFD Forum | 0 | March 3, 2012 12:19 |
Gambit Meshing of stirred mixing tank | shadyenany | FLUENT | 4 | September 15, 2011 12:13 |
CFX 5.5.1 stirred tank and LES problem | Nishant | CFX | 2 | September 13, 2002 07:11 |
