November 10, 2012, 10:02 |
Pre inflation in ICEMCFD
Rep Power: 17 |
I was trying to some how realize the pre inflation for prism generation in ICEM. I tried to generate the tetrahedral mesh with octree and then the prism mesh. Later I deleted the tetrahedral mesh but retained the prisms. The resultant mesh is inputed now in the delaunay method to fill in the tetras.
But this doesn't work. I did this to actually avoid the tetras squeezing up for the prism insertion instead I wanted them to be built in accordance with the existing prisms like the pre inflation does it in ansys meshing. Could some one please explain why it doesn't work (or) suggest a better way of realizing what I intended.
Best regards, Santhosh. |
November 15, 2012, 17:43 |
Simon Pereira
Rep Power: 47 |
The Pre-prism method is not always best because you need to generate the mesh from the prism cap (inside surface of the prisms), which is not always good enough quality for the delaunay algorithm...
But every time you have a corner, the prism cap is more distorted than the original surface. For convex situations, it may be stretched, for concave situations, it may be squished... You should also check to see if you have any overlapping elements, penetrations, etc. The delaunay algorithm has some strict requirements that must be met. One way to figure it out is to run the uncovered faces check... This will find the tops of all your prisms... Put those in a new part call PRISMCAP or something like that... Then run your mesh checks... It will find overlapping elements, etc. Run your quality checks to look for poor aspect ratio triangles...
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
Simon Pereira
Rep Power: 47 |
It could also be your delaunay settings. You want it to fill voids in the mesh, etc.
Total Thickness of Inflation Layer | prikeyma | CFX | 5 | August 28, 2020 03:22 |
Large Valve Flow Analysis - Inflation Problem | sercan85 | ANSYS Meshing & Geometry | 2 | June 1, 2010 14:02 |
Icemcfd: Preventing prism inflation collisions? | Joe | CFX | 1 | July 31, 2007 09:13 |
Inflation | Gab | CFX | 6 | August 24, 2005 22:45 |
IcemCFD 4CFX-How to fix domain | Ahmed | CFX | 6 | March 9, 2004 18:38 |
