[GAMBIT] What is the shape parameter in "Create Conic Arc" tool ?
Old   November 21, 2012, 02:02
Cool What is the shape parameter in "Create Conic Arc" tool ?
minhquan is on a distinguished road
Hi everyone
I was trying to create a conic arc which passes through 3 points using the tool in Gambit with an exact value of eccentricity ( 0 to infinity, 1 is a parabola, greater than 1 for hyperbolas), however, the tool in Gambit does not allow me to enter the eccentric value. Instead, it asks for a number called shape parameter (0.01 to 0.99, 0.5 is a parabola, hyperbola is between 0.5 and 0.99). Is there a way for me to convert between the two quantities ?
Thanks
minhquan is offline   Reply With Quote
Old   November 21, 2012, 02:54
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
http://aerojet.engr.ucdavis.edu/gamb...e_create_conic
Do you have a sketch of what you want to draw?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   November 21, 2012, 04:16
Cool
Basically I have 2 points and their midpoint is the center of the ellipses. I need to plot ellipses which pass through those two points with the symetry axis make a 45 degrees angle with the line connecting the two points and I need to vary the eccentricity of these ellipses.
So how should I put the shoulder point to make the symetry axis tiled 45 degrees ?
Old   November 21, 2012, 04:51
-mAx-'s Avatar
Maxime Perelli
I would use ellipse surface tool
http://aerojet.engr.ucdavis.edu/gamb...reate_prim_ell
fix one radius, and le vary the other radius
Old   November 21, 2012, 07:00
Cool
Because I am going to plot the hyperbola and parabola in later part of my project, thus, I need to use the conic section tool
[ANSYS Meshing] Workbench Meshing Tool - Max Face Size Parameter MaxHeat ANSYS Meshing & Geometry 3 March 2, 2021 07:50
Force can not converge colopolo CFX 13 October 4, 2011 22:03
