[DesignModeler] Defining a 2-D surface in a 3d geometry |
November 20, 2012, 18:23 |
Rep Power: 17 |
I am Using Ansys 14.0. I want to define a surface (a circle) on my 3-d geometry. But the design modeler software needs thickness and does not creates a surface in a 3D geometry. I need to determine this circle on a part of my geometry, because I need to calculate something specifically for this circle are in FLUENT. So I need to define a name for it in (named selection) then I will be able to select that in FLUENT and calculate for that area. What should I do? Please help me with this. Thank you. |
November 21, 2012, 10:36 |
Ghazlani M. Ali
Rep Power: 29 |
can you be more clear.
Just click with right button mouse on the FACE you want, for that you need to filter the selection mode to FACE. and insert a named selection. What software are you using for meshing it can be done in the meshing process as well... |
[snappyHexMesh] SnappyHexMesh Internal Flow Example (Diesel Injector) | Irish09 | OpenFOAM Meshing & Mesh Conversion | 23 | July 15, 2013 07:45 |
[ICEM] Automatic mesh generation script surface intersection problem | stuart23 | ANSYS Meshing & Geometry | 0 | May 13, 2011 01:10 |
Defining of a geometry | Gabriella | FLUENT | 1 | October 15, 2008 06:15 |
Defining a surface from points or edges in CFXpost | Gui | CFX | 9 | July 26, 2007 15:12 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 04:31 |
