[ANSYS Meshing] Help mesh a pipe cross
Like Tree15Likes
Old   December 1, 2012, 12:19
Default Help mesh a pipe cross
catrapi is on a distinguished road
Hello everybody,
I'm sorry to post this here, but i've been searching for a while and i can't do this properly. I need to study the flow within a pipe cross like this:
But i can only get this type of mesh, which i believe is not the best one:
I read about blocking and separating the part at the junctions, but i don't know how to do it in desingmodeler.
I also need to do it with three pipes crossing. I really need your help.
Thank you so much in advance!
catrapi is offline   Reply With Quote
Old   December 1, 2012, 13:38
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
take a look here, hope it can help you
http://www.cfd-online.com/Forums/ans...s-meshing.html
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   December 3, 2012, 05:01
Thank you for the answer.
Just another question: So I don't need to divide the geometry in DM because the multizone does that for me? Even if it is a bit more complex than just a simple tube? And is the mesh that I have now, good?
Thank you
Old   December 3, 2012, 05:04
I found this: http://202.118.250.111:8080/fluent/G...guide/tg03.htm
Should I try and do this in DM?
Old   December 3, 2012, 12:56
diamondx's Avatar
Ghazlani M. Ali
Best way to find out is to try, not sure of all the capabilities of Ansys meshing...
About the link you sent me, this is done using Gambit, it can also be done using ICEM CFD.
Start working on that if you want, there are good tutorial and training material that can help do that, it doesn't take too much time... we can assist you too
Regards,
Ali
Old   December 5, 2012, 11:07
I've been reading the tutorials and it says that multizone automatically decomposes the geometry. I've tried decomposing myself and it then sweep it, but i found that the elements grew worse than with multizone. So i believe this is the best method.
Thanks diamondx for helping me!
Old   December 6, 2012, 06:51
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
Lots of slicing in DesignModeler together with Multizone meshing will produce the following. It's faster in ICEM if you know it, otherwise it may be a good choice for you.
Far, RodriguezFatz, Ralen and 4 others like this.
jrunsten is offline   Reply With Quote
Old   December 7, 2012, 04:04
jrunsten, thank you so much!
In fact when I use multiblock, the mesh in the middle becomes triangular
instead of quad. And I read it should be quad in order to get best results. How did you decide where to slice the part? I mean the dimensions? Is it a "more or less like this", or do you have specific places where to slice?
Once again, thank you!
Old   December 7, 2012, 04:39
Josef Runsten
This was just some random dimensions i chose, but basically it is all scliced using planes rotated 45 degrees about the origin and then I merged the resulting pieces into the bodies i wanted. Don't forget to create a new part from the final bodies. The only dimension I set for this is the size of the square in the middle.
In ICEM, i guess this would correspond setting the size of the ogrid.
You can my files here:
https://www.dropbox.com/s/butno8c91xeb7hq/cross.wbpz
Maybe it can help someone
Asura likes this.
Old   December 11, 2012, 02:41
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
@jrunsten Good work. I have two queries:
1. How did you get the hexa meshing at the interface of four pipes (or intersection of two pipes)
2. How to make the wbpz workbench file.
Far is offline   Reply With Quote
Old   December 11, 2012, 02:55
Josef Runsten
1. It's all in the splits. See the image below. Every part in the multibody cosists of 90 degree bends, making it easy for the Multizone meshing to work
2. In Workbench, choose File>>Archive. The option to restore an archive is directly below.
Far and catrapi like this.
Old   December 11, 2012, 03:05
Far
Sijal
version 14.5 I have 14 so not possible for me to use it (your project uploaded in previous post).
Old   December 11, 2012, 03:10
Josef Runsten
Ah ok,
Well I think all the info is here anyway. Perform the slices with your preffered method, create a multibody part and then mesh them all together with a multizone method. For fine grid at the walls, right click the Multizone method and choose "Inflate this method". Choose the correct wall surfaces for each inflation instance and it should work just fine.
Old   December 11, 2012, 03:44
Hi, I have version 13, so I'm not able to open.
I tried to split the body, and I can, but I get a lot of parts, and then I'm not able to merge some parts back together (in DesignModeler). Can you please explain to me how you do that?
Thank you!
Old   December 11, 2012, 03:47
Josef Runsten
Create>>Boolean, Unite
Old   December 11, 2012, 04:32
Thank you so much for all your help! I managed to divide it. It took me a while! Thank you
Old   December 11, 2012, 08:59
I don't know if it was posted before, but I can't find it. Is there anyway that I can do a mesh just to one and then replicate it in others? Like if I want these 4 of these crosses connected, can I make a mesh just for the first cross and then make a pattern to mesh the following crosses?
Old   December 11, 2012, 09:40
Josef Runsten
Not that I'm aware of. You can certainly make a pattern of the geometry in DM, but not in meshing. A bit more work meshing four of them, but not that much.
Old   December 11, 2012, 10:10
I did it in DM, but when I try to mesh it, it takes forever, and I end up stoping the mesh... Is there any way I can speed it up?
Old   December 11, 2012, 10:23
Josef Runsten
Four in a row or 2x2 like a square?
ansys meshing, cross, pipe, pipe cross, pipe juction
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 12:41
[snappyHexMesh] No Surface-Layers on pipe with hexagonal cross sectional area U.Golling OpenFOAM Meshing & Mesh Conversion 0 December 10, 2010 09:08
[blockMesh] generate a graded pipe mesh. jenright OpenFOAM Meshing & Mesh Conversion 0 August 22, 2009 08:58
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
