October 23, 2021, 13:47 |
Meshing a loop
Rep Power: 4 |
I have a project where I have to mesh room with the inlet and outlet connected with a loop outside the room geometry. Does anyone have any suggestions where you use only one material point? Thank you! |
October 25, 2021, 14:33 |
Erik
Rep Power: 23 |
Without full understanding what you need, I can provide a simple suggestion:
1. Simply set your inlet conditions based on your outlet conditions. Temperature and other scalar values can use massFlowAve(scalar)@Outlet when defining the inlet conditions. You can modify the inlet conditions as required if that flow is heated or mixed with other flows before returning to the inlet. |
October 25, 2021, 14:55 |
Rep Power: 4 |
Thank you for your reply!
I have attached a picture of the model. I want to mesh the entire geometry but with one domain. Although i have done it with interfaces i'm not sure whether i can put the inlet and outlet as the interfaces. And when i load the mesh ino CFX, it shows inlet shadow and outlet shadow in boundary conditions. I want to run a simulation with just one fluid |
October 28, 2021, 15:39 |
Erik
Rep Power: 23 |
Either use interfaces, or combine the bodies into one multibody part in design modeler or other CAD interface.
Then it will mesh with conformal nodes at the interfaces. Of course you could just combine the two bodies into one body as well in the CAD program. |
November 1, 2021, 06:50 |
Gert-Jan
Rep Power: 27 |
What is in the loop?
icem, loop meshing |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
Pressure distribution on a wall | darazsbence | CFX | 17 | October 6, 2015 10:38 |
meshing error:the follwing faces have more than 1 external loop | stenber | ANSYS | 0 | September 30, 2015 09:06 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
