[DesignModeler] DesignModeler: Merge two named selections
Like Tree2Likes
  • 1 Post By jrunsten
Old   December 11, 2012, 03:57
Default DesignModeler: Merge two named selections
Christian Elgård Clausen
Elgaard is on a distinguished road
Does anybody know if it is possible to combine two or more named selections in the designmodeler into one named selection?
/Elgaard
Elgaard is offline   Reply With Quote
Old   December 11, 2012, 04:09
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
It's a bit easier in the meshing module, but there is a way in DesignModeler.
Select all the Named Selections you want to merge in the Tree Outline. Right click and choose "Hide Face(s)".
Then choose all the faces visible in the graphics window and create a named selection containing all these faces.
Then choose to show all faces. Next, right click on the named selection with all the irrelevant faces and choose to hide them. Then you are left with all faces of interest, and you can create a new names selection.
Again, this is easier in Meshing, where you can just right click your named selections and choose "Select Items in Group"
mohamedibr752 likes this.
jrunsten is offline   Reply With Quote
Old   December 11, 2012, 07:13
Smile
Thanks. It worked
Old   February 25, 2013, 09:45
James Willie
jwillie2000 is on a distinguished road
I saw your post below and i wanted to ask if you can help me with a similar problem. Is there a way i can merge a number of faces in ANSYS Meshing into a single face?
Thanks!
Jimmy
jwillie2000 is offline   Reply With Quote
Old   February 25, 2013, 09:55
Josef Runsten
In DesignModeler:
Tools > Merge
Choose faces, not edges
Originally Posted by jwillie2000 View Post
Thanks!
Jimmy
crevoise likes this.
Old   February 25, 2013, 11:15
James Willie
Hello Josef,
I tried what you just suggested but when i selected generate it failed. Do you have any idea why this is happening?
Thanks!
James
Old   February 26, 2013, 02:03
Josef Runsten
Not without further information. Uploading the files would be best
Old   February 26, 2013, 03:17
James Willie
Hello Josef,
Thanks again for writing back. The issue i have is that i have a fluid volume made of two bodies that i have put into one part. I need to use the sweep algorithm to mesh this part and for this the algorithm needs a single source face and a single target face. At the moment that is not the case. The trouble is how to merge two faces that do not belong to the same body? The Design modeler help is saying that the two faces must belong to the same body for this to be possible.
Do you know if i can merge two bodies into one? Or if i can merge two faces belonging to different bodies into one?
It would be great if you can share with me as well the possibility of using the enclosure feature to extract the fluid volume such that when you already have a fluid volume, a subsequent plane or surface slice would not affect that previous volume. My problem is that i get the volume around two lobes as a single volume but when i create another slice to get another volume the plane or surface cuts the previous volume thereby creating the two parts that am having problems with merging of the faces.
Thanks!
Jimmy
Old   November 25, 2014, 10:08
Default Overlapping surface in enclosure
Jonathan Koh
jonathankxx is on a distinguished road
Hi.. came across this thread. I have a similar problem whereby I created a solid block in an enclosure(fluid). However, there seems to be overlapping surfaces and i don't know why.
is there a way to remove the overlapping surfaces. or am i doing the geometry wrong?
jonathankxx is offline   Reply With Quote
Old   December 3, 2014, 00:41
Kapi is on a distinguished road
Hi jonathankxx,
Could you provide some more details about the geometry and post a pic of overlapping geometry?
Cheers
KAPI
Kapi is offline   Reply With Quote
Old   December 3, 2014, 04:55
Jonathan Koh
Originally Posted by Kapi View Post
Hi jonathankxx,
Cheers
KAPI
The geometry is a solid block(with windows) enclosed by a domain of fluid. The steps I took to create the geometry is:
1) extrude a block
2) create Enclosure
The 2 bodies were then created as One Part, but there happens to have overlapping mesh. Someone diagnosed that there is overlapping mesh, however, I dont know where is it.
The link to the case file is attached below:
https://www.dropbox.com/s/5ov6r4dzt3...haded.cas?dl=0
Old   December 3, 2014, 19:56
Hi Jonathan,
It looks like you 2 named selections for same geometry like Ceiling and Ceiling-shadow or is it fluid?
I dont have geometry and/or mesh to judge how this overlapping is coming.
My best guess is that you have either two geometry at same place or two named selection of same geometry hence you are getting overlapping error!
Hope this helps,
Cheers Kapi
Old   December 4, 2014, 05:29
Jonathan Koh
Hi Jonathan,
Hope this helps,
Cheers Kapi
Hi Kapi,
Sorry, I should have included the geometry file. Here is the step file:
https://www.dropbox.com/s/mqryakinxp...odel1.stp?dl=0
Anyway, the named selections 'ceiling' and 'ceiling-shadow' are auto generated in Fluent itself. I do not have any geometry surface that has multiple named selections.
Thanks!
Old   December 4, 2014, 20:40
Hi Jonathan,
I was not able to find any overlapping in the geometry and as u said there is no geometry with multiple named selection then I suppose there is no overlapping at all.
I was able to mesh the geometry without any errors and ran simulation without any issues!
Cheers
Kapi
Old   December 8, 2014, 00:24
Jonathan Koh
Hi Kapi
Thanks for the help! However, I was unable to reach convergence with this mesh. The min orthagonal quality was 0.055 in FLUENT.
Another question, do you think the geometry created in DesignModeler would have a different geometry in ICEMCFD ??
Thanks,
Jonathan
Old   December 8, 2014, 17:19
Hi Jonathan,
You have to find out areas where your mesh quality isn't good and give sizing to constraint the quality of element. Check Aspect ratio, skewness and orthogonal quality of elements in your mesh and re-mesh the geometry with further constraints to get a good mesh. With the right mesh,I am sure you will be able to converge.
Also, I am not very familiar to ICEM so I would not comment on that.
Hope this helps
Cheers
KAPI
only 1 of many named selections not showing up in cfx pre mihirbhagat CFX 2 April 26, 2019 04:56
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
[ANSYS Meshing] Missing Named Selections kschong ANSYS Meshing & Geometry 3 June 4, 2012 04:04
Named Selections Issue vitor ANSYS Meshing & Geometry 5 February 7, 2011 14:30
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
