[ANSYS Meshing] WARNING: 1 cell(s) have only wall faces. Error using Octree Mesh Method
Old   January 17, 2013, 03:46
Default WARNING: 1 cell(s) have only wall faces. Error using Octree Mesh Method
david
davidwilcox is on a distinguished road
I used ANSYS ICEM 14 to do my meshing of a 3d building. I used the tera/Mixed Mesh: Robust(Octree) method to do my meshing. It went smoothly in ICEM. When I imported the mesh into fluent and did a check on the mesh, the mesh-check failed. It gave me a warning.
How do I fix this? I cant seem to run anything smoothly on Fluent when my mesh-checks fail. (AMG Divergence error)
I need help. serious help
davidwilcox is offline   Reply With Quote
Old   January 17, 2013, 22:27
david
I keep coming back here every hour like this place's Facebook..lol... but still no replies on my post.
Old   January 19, 2013, 15:57
david
anybody? there should be some experts here on this matter i'm sure
Old   January 20, 2013, 01:04
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
hmmm. did you check mesh in ICEM first?
Far is offline   Reply With Quote
Old   January 21, 2013, 19:04
david
The problem is : I do not know what to check for in ICEM. I do not understand the error in Fluent. What does "2 cell(s) have only wall faces" mean?
Here is how i created my mesh in ICEM.
I imported a few .IGS files into ICEM. I imported 5 of them, merged them and then imported another 6 more .IGES files separately. Created a mesh using the Octree algorithm. It looks ok in ICEM. But when i did a mesh check in fluent, the mesh check failed. What does the error mean?
Old   January 22, 2013, 07:40
Smaras
Smaras is on a distinguished road
Hello David,
Probably it's best to go for check mesh and check the quality of mesh in ICEM prior to export the .msh file to fluent. You can find them in edit mesh tab. I am also new to ICEM and Fluent still in learning phase.
Further this user and tutorial guide as follows:
http://www.scribd.com/doc/102260831/...utorial-Manual
https://www.dropbox.com/sh/956u0shaf98jre0/x6dXXacUT0
Hope this will work.
Regards,
Smaras
Smaras is offline   Reply With Quote
Old   January 22, 2013, 23:46
david
Thanks for the Manual Smaras.
Update: I did a check in ICEM and found 16 penetrating elements on my mesh. and surprise surprise..when i did a mesh check in Fluent, i have the error: "16 cell(s) have only wall faces".
Now..another conundrum... how do i fix the penetrating elements? deleting them is definitely not an option because doing so will bring on another error in the form of missing or uncovered faces. Any help here on fixing penetrating elements?
Old   January 23, 2013, 05:16
Smaras
Hello David,
As i told you earlier i am also novice at ICEM. I am learning by hit and trial. And mostly i do google research Still long way to go.
I recently transfered myself from STAR-CCM+ to FLUENT so probably you can load your geometry, i can see but can't promise of any solution. In the mean while i am also looking into this problem if i find anything i'll share it with you and if you do then please also share would be thankful.
I think FAR or Simon can help you more in this regard.
Regards,
Smaras
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 08:07
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
