[ICEM] Volume Orientations Error ON Propeller |
July 17, 2013, 09:30 |
AhmadReza
Rep Power: 13 |
Hi
For My Master Project I need to have full structure Mesh on Ship Propeller I can produce it but i have bad element (bad mesh) on tip of blade because of Leading edge of the blade is Sharp (Line) Front of Leading edge I have Triangle Block ( I Know That is bad but i don't know How to modify it) check Mesh ICEM 14.0 Shows: ERROR: the element is too bad and shows Volume Orientation Error Please Help me How to Modify my Block Thanks http://upload7.ir/images/22350517418668597106.jpg http://upload7.ir/images/08465106212636021821.jpg http://upload7.ir/images/22447560473296158371.jpg http://upload7.ir/images/35847535113813504727.jpg http://upload7.ir/images/86102233848860599481.jpg http://upload7.ir/images/54772143397342289193.png |
July 17, 2013, 10:55 |
AhmadReza
Rep Power: 13 |
Blade Tip is a little blunt
Blade leading edge is Sharp Blade Trailing edge have fillet I cant collapse it because I have a rotary domain ( I need Two Domain For Define In Fluent & ) and I Produce A total block and I segment it to 4 block and next time I segment whole of block to O-block So I have 1 Block for 7 blades I segment it and http://upload7.ir/images/21111571856490580570.png http://upload7.ir/images/03975327150012423368.png http://upload7.ir/images/42967238947214923277.png http://upload7.ir/images/66186523225767739262.png |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
