[ICEM] Growth ratio ICEM
Like Tree4Likes
  • 4 Post By PSYMN
Old   February 3, 2013, 13:38
Default Growth ratio ICEM
Marijo
krembil is on a distinguished road
How can I set a "real" growth ratio of, for example 20% growth, for hexa mesh in ICEM?
If bigeometric bunching law is set, for a given initial height there is a range of number of elements that could be applied for the same growth ratio. In other words, there is no unique number of elements for a given growth ratio.
Thanks!
krembil is offline   Reply With Quote
Old   February 4, 2013, 09:18
Christoph
energy382 is on a distinguished road
Thanks!
depends on mesh law and if you determine spacing 1 (let's say your intitial height) and spacing 2.
so if you choose bigeometric as mesh law and set your spacing 1 to 0.1 and ratio 1 to 1.2, the nodes will be distributed on this edge with these settings.
BUT: if you set a spacing 2 to a determinated value (other than 0), Icem will retain the initial spacing 1 and spacing 2 and grow ratio, but the max. space will change OR, if it isn't possible (to less or to many nodes), you have to change to number of nodes to achieve the intended grow ratio.
energy382 is offline   Reply With Quote
Old   February 4, 2013, 17:54
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Krembil,
Bunching gives you too many controls, and
with great power comes great responsibility...
So, you could specify a small initial size and a small growth ratio, but not enough nodes to make it mathematically work out... In which case, it would just increase your ratio so it works...
Inversely, you could put too many nodes, in which case, the ratio could drop down to 1 (uniform) and your initial height could even be reduced.
You could also be setting things up on one edge and copy to another with a different overall length and end up with a different effective ratio.
This is why there are two columns in the Hexa Parameters panel... The first is what you would like... So you could put something like ratio = 1.1 in there. The second column is what you get... so if you don't have enough nodes, you could see that as ratio = 1.8...
To make the two line up, you can increase the number of nodes until you see something similar in the second column.
Do you get it? Play with it a bit and you will.
BrolY, krembil, sharonyue and 1 others like this.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   February 5, 2013, 03:32
Marijo
Thank you for your answer.
It's clear now.
Marijo
Old   April 20, 2015, 05:41
Smile Growth ratio in Unstructured meshing
Manjunatha S
manju is on a distinguished road
Hi ..
How can we control the growth rate of tetra elements in ICEM. I want smaller grid size near the wall and larger size elements away from the wall.
Please suggest me how to create it with out using prism layers.?
Regards
Manjunatha S
manju is offline   Reply With Quote
Old   April 20, 2015, 06:18
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
I do not know if this is the best way but this works for me. I use density boxes to define tetra sizes and ratios. It can be created for octree and delaunay volume meshes. Read simon's ticks and trips document. ( search in google for it, it comes to the 1st page of google search)
shereez234 is offline   Reply With Quote
Old   April 21, 2015, 00:48
Manjunatha S
Hi Shereez,
Thank you for your reply. I want to know how can i mesh without using density option. Is there any method to give ratio's ?
What is that simon's ticks and trips page? I am not getting anything relevant to this topic..!
Old   April 21, 2015, 09:46
shereez234's Avatar
M Sereez
Originally Posted by manju View Post
Hi Shereez,
Density boxes are a way of controlling tetra sizes. You create these boxes as entity bounds or from points and with a certain ratio you have in mind. But you have to know the appropriate sizes to use other wise it increases the amount of volume mesh rapidly and this is an unwanted situation.
I have uploaded to my dropbox Simon's tips and tricks 2010 google doc and also Simon's Prisms no pyramids. I found them both very useful while learning ICEM CFD. Hope this helps. Here are the links. Let me know if you can access them now.
https://www.dropbox.com/s/2m53u2c7w9...s2010.pdf?dl=0
Simon's Prisms no Pyramids:
https://www.dropbox.com/s/l0ddrxaw7h...amids.pdf?dl=0
I have also posted a mesh which i made a month ago for tetra meshing of an aircraft with density boxes. just to give you an idea I will show you a photo of it:
https://www.dropbox.com/s/hsmakw8fig...BOXES.jpg?dl=0
Regards
Shereez
Old   April 22, 2015, 07:56
Manjunatha S
Hi Shareez,
Thank you very much for your valuable information and documents..
Thanks a lot..
Regards,
Manjunatha S
Old   December 30, 2015, 00:46
Default bunching law
Amit soni
Amit soni is on a distinguished road
Dear sir ,
from where i can get the details of bunching law used by icem
Amit soni is offline   Reply With Quote
Problem with divergence TDK FLUENT 13 December 14, 2018 06:00
[Commercial meshers] [fluent3DMeshToFoam] High aspect ratio cells found (mesh from ICEM) alquimista OpenFOAM Meshing & Mesh Conversion 10 January 29, 2013 15:28
[ICEM] How to show grids expansion ratio in ICEM Anna Tian ANSYS Meshing & Geometry 5 January 26, 2013 13:07
[ANSYS Meshing] Growth ratio with body sizing saisanthoshm88 ANSYS Meshing & Geometry 1 October 12, 2012 07:51
pressure eq. "converges" after few time steps maddalena OpenFOAM Running, Solving & CFD 69 July 21, 2011 07:42
