[DesignModeler] Import of 3D-curve from .txt
Like Tree5Likes
Old   February 12, 2013, 08:32
Lightbulb Import of 3D-curve from .txt
B.Rathmann
Brathmann is on a distinguished road
Helly everybody,
as a complete beginner do ANSYS (FLUENT) I try to follow a tutorial on an airfoil with ANSYS14.
To begin with the geometry of a NACA 7420 shall be imported as a 3D-curve from a .txt file (attached).
When I import this file I get a Reading Error and after generation the
"Error: Duplicate Coordinates found in Coordinates File
Context:Curve Feature Curve5
File:<path>
Line:61"
I cant see any duplicate coordinates which I figured to be coordinates of the same group and point number nor geometrically the same coordinates.
Line 61 is the line in wich the curve's coordinates are the origin.
If I change them slightly the Error still appears
If I delete them I then get the
"Error: Points in Coordinates File are outside valid range
Context: Geometry Engine, while generating Feature Curve5"
Since I could not find the definition of the "valid range" neither in the ANSYS help nor in other threads or by experimenting I hope for your help.
(If I missed to explain relevant aspects of the problem please ask for more information)
Thank you for thinking about it
Brathmann is offline   Reply With Quote
Old   February 12, 2013, 09:33
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
For a closed curve, the file should end like this:
1 115 0.993048943 -0.002014453 0
1 116 0.996641161 -0.002030757 0
1 117 0.998801745 -0.002041384 0
1 118 0.999522818 -0.002045067 0
1 0
danielncku likes this.
jrunsten is offline   Reply With Quote
Old   February 13, 2013, 04:00
Post
B.Rathmann
Thanks for the effort. Actually I had tried that and it won't do.
The
Context: Geometry Engine , while generating Feature Curve1
Eror: Empty selection
Context: Geometry Engine while generating Featrue Curve1"
still does appear.
Btw, I read somewhere that putting the point number to zero automatically stops DesignsModeler from reading the coordinates behind it. Also I tried different coordinate inputs from other tutorials (mostly for airfoils, so basically in the same range) and even the import example of the ANSYS help gives this error.
1 1 10.1234 15.4321 20.5678
1 2 15.2468 20.1357 25.1928
1 3 5.5555 6.6666 7.7777
2 1 100.0101 200.2021 15.1515
2 2 -12.3456 .8765 -.9876
2 3 11.1234 12.4321 13.5678
2 0
What DOES WORK is this, but it stops working when I add more decimal numbers
1 1 1 0 0
1 2 2.5 3.5 0
1 3 3.5 4.5 0
1 4 4.5 5.5 0
1 5 5.5 6.5 0
1 0 0 0 0
It doesn't seem a reasonable solution for importing coordinates to only use integers. Also, when i make the airfoil data all integers, it doesn't help.
Can anyone guess the deciding difference in the data?
Or might there be any setting in ANSYS which limites the importable data range? All my settings should be the default settings though.
Any ideas?
Old   February 13, 2013, 04:26
Josef Runsten
Your original coordinate file works fine on my machine. Try switching your dots for commas (,) and see if that helps. Perhaps some language setting somewhere is ignoring your dots, making the dimensions huge.
lape95 likes this.
Old   February 13, 2013, 05:09
Lightbulb Solution: Import of 3D-Curve from .txt
B.Rathmann
Frickin genious!
Originally installed was the german version of ANSYS and I only switched the Language Settings to English. So actually the program expects kommata to indicate decimals and the dotted number got too big.
And I thought beein smart paying attention to keep the data with dots.
Thank you Joseph!
I know have a beautyful airfoil profile.
Enjoy your day
Old   March 29, 2013, 16:24
Default 3D curve text file import
Arshiya Hoseyni Chime
arshiya4 is on a distinguished road
I am having a hard time importing my airfoil data into design modeler! I follow the airfoil tutorial of workbench closely to generate my text file. I attached the file below. I am using the 3D curve However, I get the following error:
Error reading coordinates file
Context: curve feature curve1
File:/home/ahc9/workbench/naca63815_1.txt
Line:6
If I only import the first 94 points, design modeler plots it nicely however as soon as I have more than 94 points it gives me the above error!!!!
In settings, minimum number of points is set to 2000! Also, language is English( changing to commas didn't help)
I'd really appreciate any help.
Thank you
Arshiya
arshiya4 is offline   Reply With Quote
Old   March 30, 2013, 02:52
Ali
Hybrid is on a distinguished road
Your text file is inconsistent, i figured it out and attached the modified file.
First use excel that how these data points look like, arrange the data in columns and then export the file as text(tab delimited)*.txt.
enjoy!
Best Regards
Ali
Hybrid is offline   Reply With Quote
Old   April 1, 2013, 18:40
Default Thank you :)
Thank you so much Ali. It worked! I redid this in excel to make sure it works and it did.
enjoy!
Old   April 2, 2013, 06:43
Mario Belmar
Belmar is on a distinguished road
I'm new in Fluent and I have a problem with the coordinates of an airfoil NACA 2412. When I import the coordinates it shows an error message that the coordinates couldn't been read. I've put commas and the error continues. Can anybody help me, please? Sorry for my English
Thank you very much
Belmar is offline   Reply With Quote
Old   April 2, 2013, 07:45
Josef Runsten
You have selfintersecting curves:
I think you need to separate them in order to import the coordinates. Also, check you "Point Feature Limit" in Tools>Options>Miscellaneous. Perhaps your default is too small
oewnce932c and noaceshigh like this.
Old   April 2, 2013, 12:17
Mario Belmar
thanks for respond. I don't know what so you mean with intersecting curves as I look the coordinates and I don't see any point at X axis or the line at X=1. I hace changed the point feature limit as it was set at 2000 points and I had 2001! Anyway the error continues. Have I to exclude some coordinates)
Thanks!
Old   April 2, 2013, 12:54
Ali
take ur coordinate file to the excel, and put the data into columns.
then save file as text(tab delimited file). it will surve the purpose.
dnt put commas, only decimal point. ok
Best Regards
Ali
Old   April 3, 2013, 02:36
Josef Runsten
Originally Posted by Belmar View Post
Thanks!
Then explain to me points 12-14 and 1979-1999, as well as 987-1003
Open the series in excel/matlab/whatever and plot it. You'll see the points
Old   April 3, 2013, 09:20
Mario Belmar
You're right, when I put the coordinates in Excel I did something with the decimals and that made that for example 0,000095 converted into 0,95. This ocurred in some coordinates but now is all clear and I've been able to import the coordinates succesfully.
Thank you very much!
PS: I upload the coorect coordinetes for the NACA2412 for someone who could need them.
Old   April 3, 2013, 09:22
Josef Runsten
nice work
Old   September 27, 2014, 10:23
Shravan
shravansudden is on a distinguished road
enjoy!
Sir, it displays the following message.
shravansudden is offline   Reply With Quote
Old   October 27, 2014, 12:07
Post I had imported coordinates into DesignModel, only points are importing
  #17
A.P
guttasandeep22 is on a distinguished road
only points are importing, but i need curve also, how to import both point and curve... Can any one plz tell me
and also plz tell me that how to verify the Lift & Drag force values of NACA0012 or any coordinate, i had found lift and drag forces but how to knw it is correct,, how to verfy these values.....Can any one plzzzzzzzzzzzzz suggest
guttasandeep22 is offline   Reply With Quote
Old   November 5, 2014, 03:20
finaeira
fina is on a distinguished road
I am new in ansys cfx, I try to import point into geometry and then make a 3d curve. but, the problem i face is the point come out cannot snap when i try to draw a line or trim.
fina is offline   Reply With Quote
Old   February 12, 2015, 11:48
Default points name
  #19
tolga
tolgakaraca is on a distinguished road
I've created points. How do I see the name of the points? please help...
tolgakaraca is offline   Reply With Quote
Old   April 17, 2015, 22:29
Default 3D geometry import from txt.
  #20
None
ivan007 is on a distinguished road
Hi everyone,
I am a newer to fluent. I attempt to analysis flow inside of asymmetric dual-bell nozzle (z=0) in fluent 14.5 academic version. Nozzle contour is generated by Matlab, and I have generate the txt file used to import. The warraning is following:
Error 1: A minimum of two points are needed for curve creation
Context: Geometry Engine, while generating Feature Curve4
Error 2: Boolean operation failed
Context: Geometry Engine, while generating Feature Curve6
It is important to notice that, Curve4 and Curve6 are same nozzle contour, with different number of points, 250, and 4200 respectively.
The amount of points (I need) is 2e4 (or 4000) in txt file in total. However, it doesn't work when first 300 points are imported. I use same method to import 3D (asymmetric nozzle) successfully, but failed in this model. I have already deleted the duplicate points (only two). Plot (x,y) from Matlab and Excel show that there is no curve intersection.
I don't know how to deal with this problem, so I do really wish your help.
If I miss some information, please let me know.
Thanks for your time,
Xiaohua
Nozzle Contour First 2500 points.txt
Nozzle Contour Point No. 2501 to end .txt
ivan007 is offline   Reply With Quote
3d-curve, coordinates from .txt, geometry import
[ICEM] How to import point coordinates from .txt sixfor ANSYS Meshing & Geometry 2 January 19, 2011 12:44
import matrix from .txt hbf FLUENT 1 January 28, 2009 04:48
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
how to import the curve into blade gen fadly CFX 2 August 23, 2007 04:27
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
