[GAMBIT] examine mesh
Old   February 12, 2013, 15:54
Default examine mesh
toshiba
kato is on a distinguished road
hi every one
how can i see the mesh generation in gambit(examine mesh) is true?
kato is offline   Reply With Quote
Old   February 14, 2013, 02:38
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
go to examine mesh, and check if you have elements with skewness between 0.9 and 1
The transcript window also gives you precious info once your volume mesh is done.
Gambit gives your warning/error if you have negative volume,etc...
But more powerful is the check mesh of your solver
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
[GAMBIT] Examine Mesh Problem Mezar ANSYS Meshing & Geometry 1 April 30, 2012 02:42
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
