February 24, 2013, 11:45 |
Selecting inner faces
Jasdeep
This might sound like a silly question but how to select an inner surface in a solid.
I am trying to do an aircraft wing analysis. in order to have higher density mesh near the surface of the wing, i am selecting the 'face sizing' option in mesh. it is okay with half wing since the wall is at the root of the wing. how to do 'inside' when the 'wing shaped hole' in inside the control volume. |
February 25, 2013, 01:56 |
Click where you see the surface and then go "trough" other surfaces by selecing the appropriate layer:
Hard to explain in words, but I hope you get it |
February 25, 2013, 05:23 |
Thank you
Jasdeep
Snap showed it all, thank you very much
June 13, 2018, 22:31 |
changxiyuan
Rep Power: 7 |
HI is this from Space claim ?
March 5, 2019, 02:25 |
For Ansys Fluent
Rudra Lad
You should select the outer faces, then right click and select hide face (F8).
That's how you can have access to inner surfaces. |
mesh, wing |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[Other] Mesh Importing Problem | cuteapathy | ANSYS Meshing & Geometry | 2 | June 24, 2017 05:29 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
