[ICEM] Lines do not snap to curvature in pre-mesh |
January 11, 2016, 08:39 |
Rep Power: 13 |
Hey,
I want to mesh a cylinder in the flow. I O-grid it and associate the lines of the O-grid to the curves (see pictures). When pre-meshing it the mesh does not follow the curves but rather straight lines. Why is that and even more important how can I fix that? |
January 15, 2016, 13:01 |
Gwenael H.
Rep Power: 20 |
Sometimes this can happen in ICEM. You should first check under the pre-mesh that you didn't activate "no projection". In the model tree, under blocking, rmb on premesh and check that "project faces" or "project edges" is selected.
If this is already the case you can update the associations, under the blocking tab > associate icon > Update associations (6th icon) > apply. If this still doesn't solve your problem you should disassociate all the blocking from the geometry (disassociate all vertices, edges and faces) and start over again. Have fun |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] snappyHexMesh doesnt snap | staustrahltriebwerk | OpenFOAM Meshing & Mesh Conversion | 47 | March 18, 2018 14:19 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
