[ICEM] smooth curves from points
Like Tree1Likes
  • 1 Post By darkEnergy
Old   March 5, 2013, 16:30
Default smooth curves from points
Mamdouh
mrenergy is on a distinguished road
Hi everyone,
when I import the coordinates of my airfoil (points, curves, and surfaces) the leading edge get somewhat sharp and doesn't pass over the points exactly when closing it up.
I imported the points only and drew the leading edge manually, it became smoother, but is very expensive in time consumed.
how can I get my airfoil smooth and accurate without hitting each point to draw it manually?
thanks in advance,
Mamdouh
mrenergy is offline   Reply With Quote
Old   March 9, 2013, 16:08
Matt
darkEnergy is on a distinguished road
How many curves are you importing? To get the smoothest curve you should import only 1 curve, say you import 80 points and 80 curves you're just going to get a bunch of straightlines. the more points per curves the smoother the curve.
I hope this helps.
darkEnergy is offline   Reply With Quote
Old   March 9, 2013, 17:33
Mamdouh
thank you Matt, for your reply.
for one run, I have one airfoil with two curves (upper and lower surface), 90 points each.
but I have about 30 airfoils.
actually, I imported the coordinates file as points without curves, then drew the two curves by hitting each point. the leading edge get smoother.
Besides, I used the reply script to repeat these steps for the other airfoils.
but I am asking if there is another more modern way for more complicated applications.
Old   March 9, 2013, 17:46
Matt
I see, it's funny I'm actually doing something very similar but instead of importing the points (because every airfoil has a different number of reference points) I only import the curve into a template file I've created that contains the far field and then I run a replay script that adds about 160 points to the curve and then does all the geometry, associating and meshing for me. Once the script is done I just double check the mesh and save. It saves so much time.
mrenergy likes this.
[snappyHexMesh] .STL: non-closed manifold surface giulio.topazio OpenFOAM Meshing & Mesh Conversion 32 November 25, 2016 03:15
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[DesignModeler] DM's JScript: FPoint()'s GetPoint(i) function picks points backwards? ANT ANSYS Meshing & Geometry 2 July 23, 2012 15:25
[ICEM] How to get points, curves, surfaces from unstructured mesh? TKE ANSYS Meshing & Geometry 0 October 21, 2011 10:01
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
