[GAMBIT] highly skewed elements in gambit
Old   May 8, 2013, 22:13
Default highly skewed elements in gambit
omar
galapago is on a distinguished road
hi
i'm trying to mesh a gas turbine blade with cooling holes using Gambit, the mesh is structured, but in when i mesh a volume a message appears "mesh of volume 56 contains 36 highly skewed elements", however Gambit mesh the volume, at other times a similar message appears too, but Gambit dont allow to mesh the volume. my question is: if Gambit allow to mesh the volume can i to use this mesh? the area where the highly skewed elements are located isn't the area that i try to analyze.
thanks in advance guys
best regards
galapago is offline   Reply With Quote
Old   May 13, 2013, 01:37
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
highly skewed cells mentionned from Gambit have skewness greater than 0.97, which should faild check mesh in fluent.
You can try working with this mesh, but if it diverges, or doesn't start, you know what you have to do...
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   May 13, 2013, 10:33
omar
thanks a lot Max.
Highly Skewed Cells chrisoturner FLUENT 7 July 22, 2010 06:43
[GAMBIT] 3D skewed elements chris21 ANSYS Meshing & Geometry 2 May 6, 2010 21:15
active analysis elements in GAMBIT yan FLUENT 0 April 28, 2006 01:46
highly skewed elements srikanth Main CFD Forum 1 February 21, 2006 08:15
Gambit: skewed mesh Christoph FLUENT 1 November 7, 2005 12:32
