[DesignModeler] Equivalent of 2D edge projection in 3D?
Old   June 10, 2013, 18:55
Default Equivalent of 2D edge projection in 3D?
Colin Heye
cheye is on a distinguished road
I have been running a simple 2D axisymmetric periodic pipe flow in FLUENT driven by a fan. In 2D, ANSYS DM allows the projection of an edge onto a face, which is the only way I am able to make that edge appear in the Meshing tool and assign it a name.
My question is how do I create the same projection on revolved material for a 3D equivalent to the 2D pipe? I need to include the swirl component of the fan flow in my FLUENT simulations which requires a 3D simulation.
Note that my eventual plan is to utilize a small wedge (~5 degrees) and apply rotationally periodic boundary conditions, in case the procedure is different for this configuration.
Thanks!
cheye is offline   Reply With Quote
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
[Commercial meshers] Star mesh import problem chris1980 OpenFOAM Meshing & Mesh Conversion 20 May 8, 2006 01:07
