[ICEM] Questions about Hexa Meshing
Old   June 17, 2013, 16:26
Default Questions about Hexa Meshing
mohamed khedr emam
m5edr is on a distinguished road
Hi Experts,
I have some questions about Hexa Meshing of My problem (one blade inside huge sector of 120° (three bladed turbine) , theses questions my be primitive because i'm beginner in HexaMeshing and Blocking techniques
1- Is iam meshing the huge 120 degree volume (using quarter O-grid) and improve its quality firstly then start with blade OR start with blade then the huge volume ?
2- For the attached Figure 1 , why the all volume (or surface) not meshed
3- Why the color of o-grid Blocks in my ICEM is (red) while in all tutorials are (green) .. Figure 2, is it setting adjusting or i miss some thing?
m5edr is offline   Reply With Quote
Old   June 17, 2013, 16:32
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
You have a problem with your associations. right button click on edges then select "show associations" so you can detect which edge is associated with which curve. your problem is more likely to happen if you have two curve and you tought of them as one
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   June 17, 2013, 16:45
mohamed khedr emam
Thanks diamondxfor replay , now i understand this
Could i ask you to review my first and third inquiry?
Thanks in advance
Old   June 17, 2013, 17:05
diamondx's Avatar
Ghazlani M. Ali
color of block does not really matter, if you right button click on parts-»good color"", it will change i think
Regards,
Ali
Old   June 17, 2013, 18:04
kad
kad will become famous soon enoughkad will become famous soon enough
The color of the blocks is very similar to the color of some part of your surface mesh. Maybe they are in the same part. Did you create a material point like "FLUID" ? If not, you have to. Otherwise you will get problems later. Normally blocks are assigned to the part of the material point automatically.
kad is offline   Reply With Quote
[ICEM] ICEM Hexa meshing tutorial - Wing with sharp trailing edge Far ANSYS Meshing & Geometry 34 October 21, 2013 05:46
[ICEM] ICEM Hexa Meshing Butterfly Valve (Structured) snpradeep ANSYS Meshing & Geometry 3 November 23, 2012 09:26
[ICEM] hexa meshing tmeysam92 ANSYS Meshing & Geometry 8 June 26, 2012 13:09
[ICEM] Meshing adjacent wall geometry and simple ICEM questions everdimension ANSYS Meshing & Geometry 25 June 20, 2012 04:25
Icem Hexa 2d aerofoil meshing Ste Lakey CFX 0 August 25, 2004 07:05
