June 22, 2013, 13:04 |
High Skewness
mohamed khedr emam
Dear experts, My Geometry (old case () is a single blade inside a big 120o enclosure sector , after long period i'm stuck with T-Grid skewness problem around the blade surface which appear strongly in Fleunt (after send my file from ICEM). The ICEM T-Grid skewness is high but quality and skewness are good. I'm using Tetra, unstructured and Robust (octree) meshing techniques, I need a recommended ways to improve T-Grid skewness in ICEM (not Fluent). Note: I noted that if the total height of blade prism is large, T-Grid skewness will be good but unfortunately in my case the first layer is very small (4e-5) due to y+ condition image1: prsim image2: High T.Grid Skewness elements on blade Thanks in advance
June 22, 2013, 16:31 |
mohamed khedr emam
Hi Far
At blade surface seems to be between prism and blade surface mesh , here is the file http://www.4shared.com/rar/eJGwRtle/email.html |
June 23, 2013, 22:30 |
mohamed khedr emam
Any recommendation please
June 28, 2013, 03:01 |
Dealing with sharp trailing edge
Hi mate,
I suggest make these changes in order to have higher quality mesh: First as seen in the picture, shell mesh quality is of low quality. As said, garbage in, garbage out. Try improve quality higher than 0.5 by splitting and recreating cells at those areas. Then run delaunay to have volume mesh. I ran these two steps and my delaunay mesh quality was more than 0.4. Next step is to grow prism. Prism meshing is somehow try and error process. Try these methods: Make max prism angle 180, active/inactive Auto Reduction (in Advanced Prism Options) try floating height by not setting initial height and total height. The candidate area of bad quality prism is sharp side of airfoil. Try filleting that area with CAD software. You can try Mulitizone Blocking, which would give high quality quad shell mesh in all of surfaces but one. (Blade Tip) Beside these, you may have higher prism quality with TGrid, but because of periodic boundaries (i think) you can not export your mesh to TGrid. |
Removing cells with high skewness | Parag Gadgil | FLUENT | 0 | July 11, 2011 01:52 |
TGrid High Skewness | khimkhim | ANSYS Meshing & Geometry | 1 | February 17, 2010 23:36 |
Severe nonorthogonality and severe skewness problem | qtian | OpenFOAM Running, Solving & CFD | 2 | January 22, 2008 18:47 |
Interface between meshes and high skewness | Danny | FLUENT | 0 | September 13, 2005 11:23 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
