June 25, 2013, 21:58 |
faces are missorinted.. repair holes
mohamed khedr emam
Rep Power: 14 |
Dear experts, I have a small problem , it took long time for solving and i couldn't solve it When I run the mesh ( Tetra, unstructured and Robust (octree) meshing techniques) a massage appeared in monitored screen "faces are missorinted" and then ICEM show me "repair holes" massage box "image1" Notes: 1-There is no holes in my geometry (it a single blade inside a big 120o enclosure sector) and i am also run "repair geometry" before 2-The zone where the problem originates is >> a common edges between two couple of surface "image2" 3- I searched in cfd-online search for " faces are missorinted" but I found only one thread and it was useless for me Finally, I attached the Icem file Thanks in advance
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[Other] Mesh Importing Problem | cuteapathy | ANSYS Meshing & Geometry | 2 | June 24, 2017 05:29 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
