[ICEM] Rotating Mesh and export Mesh
Like Tree5Likes
  • 3 Post By PSYMN
  • 2 Post By huyaoyu
Old   August 12, 2013, 06:52
Default Rotating Mesh and export Mesh
AhmadReza
ahmadreza is on a distinguished road
Hi To all
I Want to rotate A Mesh around one blade to have mesh around whole of propeller.
after Mesh convert to unstructured I rotate the in Edit Mesh Menu
A Mesh successful rotated. But my problem here When i Export Mesh to CFX just mesh of around one Blade Comes not Whole Mesh?
What can i do to have whole mesh ( mesh from rotating ) ?
ahmadreza is offline   Reply With Quote
Old   August 13, 2013, 08:46
PSYMN's Avatar
Simon Pereira
My guess...
You saved your project before rotating...
Then you did the copy rotate, but did not save after...
Then you exported to CFX.
The exporters are all actually separate mesh conversion utilities. They read in a saved file and export in another format. (as opposed to converting the mesh already in memory)
If you didn't save your rotated mesh, it would have converted the last one you saved.
Save your rotated mesh and try again.
CFD Online Users Survey
Old   August 13, 2013, 16:21
AhmadReza
thanks Simon
No Unfortunately it is not correct ,
When I Open My Project (ICEM CFD) The Mesh is Complete and Successful Rotated.
But When I Click On Pre-Mesh And Click to Convert To unstructured Mesh , The ICEM Ask Me Merge Or Replaced and When i Click Replaced Just the Mesh Of one Blade exist And Rotated Mesh Was Removed.
When you Told Me That First Saved The Project Then Export The Mesh..
I Try To (SAVE AS) And then Exported to CFX But It is not Successful And Just One Blade Mesh Alone Exported.
Know What is Your Guest???
Old   August 17, 2013, 03:16
AhmadReza
Simon
Know What is Your Guest????
Old   August 17, 2013, 13:19
PSYMN's Avatar
Simon Pereira
Oh, I think I may know what you have done...
Do you have the premesh in the original position, and then you converted to unstructured... Then you rotated the unstructured mesh...
At that point, you were looking at a mixture of structured premesh and unstructured mesh.
The output only sends the mesh...
To succeed... You will need to rotate with the option to make a copy...
Turn off the display of your premesh. What remains will be unstructured mesh. Save and output that.
Best regards,
Simon
Old   August 17, 2013, 15:41
AhmadReza
thanks a lot simon for your answer
Yes .
I Make Structure mesh For One Blade then Converted To Unstructured Mesh
And with use Rotating Mesh (In Edit Mesh) I Can Rotated mesh
Whats meaning of : (To succeed... You will need to rotate with the option to make a copy... )
Now I dont know What u told to me..
exactly Where i Can Convert Whole Mesh To Unstructured Mesh ?
Thanks
Old   August 20, 2013, 09:12
hassan
86682164 is on a distinguished road
Hi
I have a same problem with rotating...
I dont know For Rotating Mesh : Must rotate the block or Rotate The Geometry Or Rotate Unstructured Mesh ????
I was examined each 3 Mode that I Writed in up. but i can not export rotated
mesh.
When I just Rotated Unstructured mesh it is necessary that make a Body for Rotated Unstructured Mesh ?
I Attach a very Simple Geometry For Rotate
Please rotated it And Put Exported Mesh ?
86682164 is offline   Reply With Quote
Old   August 26, 2013, 12:00
PSYMN's Avatar
Simon Pereira
I will try again to explain...
you just converted a sector of premesh to unstructured mesh and then rotated it... On the screen you could see both the premesh and rotated unstructured mesh, but export only sees the unstructured mesh.
The solution is just to add the option to "copy" when you rotate... You can then turn off the display of the premesh and see multiple sectors of unstructured mesh that will export.
If the nodes are coincident (as with a periodic model), you could also merge nodes with a tolerance (small tolerances, 1/10th the mesh size) and delete the shell elements on the periodic wall between the volumes (to open it up as one larger volume).
ahmadreza, 86682164 and mahdi6788 like this.
Old   August 31, 2013, 05:13
AhmadReza
Simon .
Unfortunately I Can't Rotate And Export Mesh
I Decide to Show What I do to you.
1-it is the geometry of hassan .
http://upload7.ir/images/86467413590441282231.jpg
2-Convert To Unstructured Mesh
http://upload7.ir/images/11053396025524176254.jpg
3-Mesh transform of in Edit Mesh
http://upload7.ir/images/99447075373305141255.jpg
4-After Rotate
http://upload7.ir/images/72462587688260489051.jpg
5-Saved Project
http://upload7.ir/images/53697081167250400666.jpg
6-Mesh Export in Cfx
http://upload7.ir/images/93106207541048715522.jpg
Where is My Problem ??
Old   January 28, 2015, 09:04
Yaoyu HU
huyaoyu is on a distinguished road
Hi ahmadreza,
I don not know if you had solved your problem in these 3 years. If not, I suggest you turn on the "volumes" branch under the "mesh" node of the tree view on the left of ICEM-CFD panel just before transforming any unstructured mesh.
ICEM-CFD will not display the volume mesh by default. So be careful when you use the selection functionality of "select all visible" (hot key "v") provided by the software.
Best regards,
Yaoyu Hu
mahdi6788 and meku like this.
huyaoyu is offline   Reply With Quote
Old   July 12, 2015, 04:17
Default propller domain meshing
  #11
sohrabmajd is on a distinguished road
hi 2 all
I'm new user of ansys that want to use ansys cfx for a ducted propeller.
i can't mesh my model as good as that my solver give me best results.
how can i mesh my model with boundary layers that have fine meshes near propeller and duct and meshes grow slowly linearly with distance from the duct?
I work with ansys workbench and fluid flow(CFX).
thanks
sohrabmajd is offline   Reply With Quote
[ICEM] Export refined mesh to fluent Heleen ANSYS Meshing & Geometry 8 March 26, 2012 08:33
Export 2D mesh from ICEM to Fluent BuilttoSpill ANSYS Meshing & Geometry 4 August 28, 2010 08:16
mesh missing after export in gambit morteza08 ANSYS Meshing & Geometry 1 July 26, 2010 01:10
mesh missing after export in gambit morteza08 Main CFD Forum 0 July 23, 2010 02:19
