[ICEM] Turbine meshing issue
Old   February 15, 2016, 12:09
Default Turbine meshing issue
Neys Schreiner
Neys Schreiner is on a distinguished road
Hi everyone,
I am currently trying to mesh a turbine blade using ICEM and am running into a problem I can't seem to solve. I'm hoping some of you may be able to shed some light on what is going wrong.
I bring geometry across from my CAD package in .iges format and rename some of the parts so it's easier to keep track of things. I have also been using build topology to merge some stray vertices on a part by part basis. I create two material points, one for the fluid and one for the solid blade.
Following this I go straight to create block using the 3D bounding box option, with some simple associations of the block to my blade passage (vertices etc). However, when I view the pre-mesh, I get problems between the blade surfaces. In this region the cells appear as per the attached image.
Is this an issue with my geometry or have I missed a key step in ICEM?
Thanks in advance for your help,
Neys
Neys Schreiner is offline   Reply With Quote
Old   February 16, 2016, 11:36
Attique Javaid
attiquejavaid08 is on a distinguished road
Originally Posted by Neys Schreiner View Post
Hi everyone,
Neys
https://www.youtube.com/user/turboengineern
go through his channel. he has a blade meshing tutorial in ICEM. gl.
attiquejavaid08 is offline   Reply With Quote
Blocking for hexa meshing of diffuser augumented wind turbine zeeshu Mesh Generation & Pre-Processing 0 February 10, 2016 17:37
CFD analysis on wind turbine rotor Ken (Wind Turbine CFD Super Rookie) Main CFD Forum 45 February 9, 2016 14:07
Guidance needed regarding the Meshing issue sidharth9426 STAR-CCM+ 5 November 9, 2015 11:56
[DesignModeler] Solid and Liquid modelling and Meshing Issue nvarma ANSYS Meshing & Geometry 4 April 10, 2015 02:27
meshing a rushton turbine Randheer Yadav FLUENT 5 September 24, 2010 03:12
