[ICEM] Edges - Change Fractions
Like Tree1Likes
  • 1 Post By diamondx
Old   August 21, 2013, 10:23
Default Edges - Change Fractions
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Hi guys,
I need some help in ICEM. I splitted a block, but with acticated "index control", so the edges are only splitted in this block, but not in the other adjacend blocks. Please see the picture: "Edge I" is a single edge but is divided into "edges II" and III in the right block. Now, "edge I" has 26 nodes, "edge II" has 12 nodes and "edge III" has 15 nodes, so they add to "edge I".
My question is: How can I change the fraction of how nodes of "edge I" are divided into "edges II" and III? I want more nodes in "edge II" but keep the total number of nodes (of "edge I") constant. Is that possible?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   August 21, 2013, 10:32
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
YES
Andrea1984 likes this.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   August 22, 2013, 02:39
Philipp
Hey diamondx, great, that worked. Do you also know, where this information (fraction) is stored before I use the linked bunching?
Old   February 16, 2016, 03:01
Philipp
I need to bump this old thread with a new, similar question.
Diamondx showed what to do with the linked bunching. Now in my current case I have a long edge in the middle (as in the post from diamondx) and smaller, divided edges on both sides.
If I set the fractions on the left edges and in the middle correctly, everything is completetly messed up and distorted on the right edges. And vice versa.
Is there any way I can get an equal distribution here?
This is a picture of the blocking (black) and the edges (red). Right side is fixed here, left side is garbage. If I fix the left side, then the right side is garbage.
LinkBacks (?)
LinkBack to this Thread: https://www.cfd-online.com/Forums/ansys-meshing/122525-edges-change-fractions.html
Posted By For Type Date
Cfd Online Discussion Forums - Ansys Meshing & Geometry Rss Feed This thread Refback August 22, 2013 06:08
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[ICEM] mesh is not aligned with edges OliverL ANSYS Meshing & Geometry 0 November 7, 2011 07:59
Edges in Gambit Naghman Khan FLUENT 3 October 3, 2007 06:36
Simple Meshed Edges Problem Rich Main CFD Forum 1 February 9, 2005 01:38
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
