[ICEM] Speicherschutzverletzung status 139 SegFault?
Old   October 3, 2013, 06:04
Default Speicherschutzverletzung status 139 SegFault?
Christian
derkaiser is on a distinguished road
i'm meshing a vaned duct with icemcfd. I want to generate an unstructured mesh from an all tri surface mesh.
For surface meshing i used the patch dependent and patch indipendent algorithm. Minimum quality of the surface mesh after smoothing is about 0,45. The mesh has no errors (holes etc.)
Afterwards i tried to generate a tetra volume mesh with one layer of prisms which i want so split afterwards to resolve the boundary layer. For this i used the octree mesher and the delaunay triangulation. Mesh generation process runs but does not create a volume mesh.
The last messages icem prints are:
updating node connections
trilateral round to curve
status 139
applicatioin is finished
Error: tetra didn't create ./tetra_mesh.uns
I searched for status 139 and get a clue, that this means a segmentation fault. I can assure, that i do not run out of memory. I also tried different resolutions for the surface mesh but with no success.
Now i'm quite clueless what to do to get a successful generation of the volume mesh.
Maybe someone can give me a hint?
derkaiser
derkaiser is offline   Reply With Quote
Old   October 3, 2013, 07:02
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Can you please show some pics?
Why you are running patch dependent and octree at the same time?
Far is offline   Reply With Quote
Old   October 3, 2013, 08:47
Christian
I will add some pictures later.
Is there a problem running the octree mesher with a given surface mesh? In my understanding the surface mesh should be used as an input for the octree mesher. I tried to close the mesh and only run the octree mesher but with the same results.
Does anyone know, what status 139 means?
Old   October 3, 2013, 09:37
Far
Sijal
For octree, surface mesh is not required.
Old   October 3, 2013, 16:26
Christian
Seems like in my case, a surface mesh for octree is required. When i close the mesh and want to calculate the volume mesh using the octree module, i get an error message, that there's no mesh.
I guess, that there is some error with the saving of the calculated mesh. May this be the case because i'm am using an academic teaching license?
Old   October 4, 2013, 03:08
Christian
Here are two pictures of my geometry. I use a symmetry plane to reduce the cell number.
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
[swak4Foam] Installing swak4Foam to OpenFOAM in mac Kaquesang OpenFOAM Community Contributions 22 January 21, 2013 11:51
cfx5post in batch mode on "graphics-less" Linux frankyd CFX 3 April 12, 2011 16:47
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
"exception : return code 139" june Siemens 0 January 8, 2008 20:20
