[ICEM] edges parameters
Old   November 3, 2013, 15:19
Default edges parameters
Domenico
c120613 is on a distinguished road
Hi All,
I am pretty new in ICEM and I am trying to create a boundary layer by considering a specific distribution on the edge parameters. At the moment I am considering a bi-geometric mesh law (see attached figure). The problem is that apparently everything seems to be frozen in the sense that although I try to change a parameter, nothing changes. Do you have an idea what is going on?
Many thanks in advance
c120613 is offline   Reply With Quote
Old   November 4, 2013, 15:40
Cesar
cesarcg is on a distinguished road
Send a message via Skype™ to cesarcg
Perhaps you have activated the "edge parameters locked" option over some edges of your blocking in the "Premesh params" dialog box showed in the picture.
cesarcg is offline   Reply With Quote
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 05:52
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
