[ANSYS Meshing] Anish K. John
Old   December 5, 2013, 12:24
Smile Ansys geometry meshing, perforated plate, Anish K. John
Anish K. John
anishkjohn is on a distinguished road
Dear all,
We have a meshing problem while using Ansys Workbench 14.
The geometry is 50 mm diameter plate having thickness of 0.3 mm. Inside the plate, there are 350 perforations of diameter 1mm arranged in rectangular pattern. The geometry is made in Autocad Inventor and imported as x_t file.
Another annular ring of outer diameter 50mm and inner diameter 46 mm is also made.
It is then stacked together alternately with 10 plates and 9 annular rings.
Course meshing is done. But the result obtained is having 0.99 skewness value and on solving, it diverges.
So we changed into very fine meshing with node size or ~3500000, then the skewnesss value reduces to 0.94 but orthogonality value is in 10^-2 value.
How can we reduce the skewness and orthogonality value so that a convergence happens during the result?
Thanx in advance!
anishkjohn is offline   Reply With Quote
Old   December 9, 2013, 05:38
vidyanand
Vidyanand Kesti is on a distinguished road
Please use smooth and swap option to improve the quality in mesh or
Try convert tet cell to ploy cell in fluent
Vidyanand Kesti is offline   Reply With Quote
ansys workbench 14, meshing 3d, orthogonal quality, perforated plate, skewness
Re John D Anderson -ebook John Main CFD Forum 2 April 17, 2006 07:40
one-year without John C. Chien temporary historian Main CFD Forum 14 November 4, 2002 12:57
John Chien? stephen davis FLUENT 0 January 4, 2002 11:17
Where is John C. Chien ??? Everybody loves John C. Chien Main CFD Forum 21 October 8, 2001 18:18
John C. Chien, WHO ARE YOU ? Anis MAALEM Main CFD Forum 14 September 5, 2000 14:18
