[ICEM] Merging surfaces/creating surface
Old   December 18, 2013, 20:48
Default Merging surfaces/creating surface
MK
MateuszK555 is on a distinguished road
Hi guys!
I'm beginner and I encountered following problem:
--- http://postimg.org/image/jkxtomhyx/ ---
How can I merge or create surface between those two elements ? I was trying to use option: "Create surface from 2-4 Edges" and selected 2 edges, but it didn't work. Is there better way to do this ?
Cheers,
Matt
MateuszK555 is offline   Reply With Quote
Old   December 18, 2013, 21:53
kad
kad will become famous soon enoughkad will become famous soon enough
There is a create surface from curves option so you can select more than 4 curves at a time. But I don't think it will actually work. More complex geometry modification is much easier in CAD modelling e.g. DesignModeler, so I would strongly recommend you to go back to CAD. It is because of ICEM's surface based structure.
kad is offline   Reply With Quote
Old   December 19, 2013, 09:06
Matthew Rich
FreeFall79 is on a distinguished road
I second kad's comments. I am a beginner as well and spent quite a few hours banging my head against the wall trying to stitch and merge surfaces. I was successful a few times of deleting one surface and trying to extend the other to the curve boundaries but that was rare.
Back to CAD with you
good luck!
FreeFall79 is offline   Reply With Quote
Old   December 19, 2013, 11:44
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
if you have just the iges file, you can use spaceclaim. It is handy tool...
Far is offline   Reply With Quote
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Comsol (4.3): convert parametric surface into block? sgalaz COMSOL 0 November 9, 2012 09:20
Different surface incident radiation between surface and surface-shadow Cortomaltese FLUENT 0 July 16, 2011 07:00
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
