[ICEM] remesh one surface without regenerating the whole 3D mesh
Old   January 16, 2014, 18:22
Question remesh one surface without regenerating the whole 3D mesh
openfoammaofnepo is on a distinguished road
Dear All,
Now I have a complete 3D mesh that can be successfully used for the numerical simulations. Now I just would like to refine one surface mesh (I know the internal mesh will be locally modified acccordingly) but do not want to regenerate the whole 3D CMC mesh. I tried the following approach (but it failed):
Assume that I have the geometry. Set the parameters for the parts and bodies. Then choose octree method to generate the purely tetrahydron mesh. Then I use Denauly mesh (Because finally I would like to get the mesh from Delauny method). So now I get the mesh which can be used for the simulations. Based on this mesh, I just would like to refine one boundary surface but not delete the global mesh. I think I just want a local modification.
Does anybody know how can this be performed for my purpose using ICEM? Thank you in advance!
openfoammaofnepo is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
