[GAMBIT] Not create wall.shadow (couple)
Old   December 18, 2010, 13:54
Default Not create wall.shadow (couple)
ekkapong
nuengao is on a distinguished road
Dear all
I would like to simulate conjugate heat transfer in Fluent, and I make the mesh by using GAMBIT. My model consists of solid and fluid zone , when I imports the mesh into Fluent why the wall shadow is not generated?
cold anyone help me?
nuengao is offline   Reply With Quote
Old   December 19, 2010, 00:12
Real Name :)
ComputerGuy is on a distinguished road
If you haven't split the volume and maintained connectivity, this can often happen. Check to ensure the volumes are connected, then give it another shot!
If this doesn't work, post a journal if possible and we'll see if we can help.
ComputerGuy
ComputerGuy is offline   Reply With Quote
Old   December 19, 2010, 03:41
ekkapong
ComputerGuy
Dear ComputerGuy
My work does not work yet, I need your help please. I'd like you to check where it is wrong but I can not attach file on this Reply (I don' know how to do). Can I send it to you by email and can I have you email ?
my email is: nueng_en257@hotmail.com
thank you
nuengao
Old   December 20, 2010, 13:54
Real Name :)
Check your email. Problem fixed.
ComputerGuy
Old   December 21, 2010, 02:36
ekkapong
ComputerGuy
Dear ComputerGuy
I already got it.
Thank you very much
Old   April 14, 2014, 07:41
Default I have the same problem
Simon
simon_sand1 is on a distinguished road
Hello Computerguy,
I have a very similar problem. I drew my mesh in gambit and read it into fluent 15 and then I face two problems:
1) I cant check my wall to be coupled
2) It seems like Fluent do not understand the interface between my fluid and solid
Case desciption:
I have heat transfer from the surrounding gas into in the two pipes. The fin and pipes are solids. I want to specify a temperature on the inside of the pipes and an inlet temperature for the gas.
I hope you want/can help me with my problem.
Simon
simon_sand1 is offline   Reply With Quote
Meshing a Sphere Ajay FLUENT 10 September 3, 2016 14:18
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
