[ICEM] Meshing of Zero Thickness Walls
Like Tree4Likes
  • 1 Post By bharath
  • 1 Post By praveen@cfd-online.com
  • 2 Post By Far
Old   April 1, 2014, 19:00
Default Meshing of Zero Thickness Walls
Engineer
nnprashant is on a distinguished road
Hallo
Guys need information/help to mesh a baffle or a zero thickness wall inside a heat exchanger using ICEM CFD ??
Any Suggestions ???
nnprashant is offline   Reply With Quote
Old   April 9, 2014, 07:39
Bharath kumar
bharath is on a distinguished road
Hi nnprashant,
Whether you are using Hex blocking or Tetra meshing?
If you are using Hex blocking you need associate blocking faces with baffle surface.
In tetra meshing naming it self enough.
bharath is offline   Reply With Quote
Old   April 9, 2014, 11:30
Thumbs up
praveen@cfd-online.com's Avatar
Praveen Kumar R
praveen@cfd-online.com is on a distinguished road
I would like to add something on bharath's comment.
In case of tetra meshing, we need to specify the baffles (zero thickness walls) as 'int wall'. To do this:
Before computing mesh,
Under Mesh tab > select Part Mesh Setup > tick on int wall check box against the baffle part.
This will make sure surface mesh is generated on the baffles or zero thickness surface (surfaces that have same material point on its both sides)
Happy Learning!!!
Praveen Kumar R
clivemathe likes this.
praveen@cfd-online.com is offline   Reply With Quote
Old   April 13, 2014, 00:02
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
I have just prepared a small video explaining the methods just described by bharath and praveen for hexa and tetra meshing methods...
Baffle/zerothickness/internalwalls
Far is offline   Reply With Quote
[ICEM] Meshing of a Flat perforated plate (Zero thickness) hammer ANSYS Meshing & Geometry 6 December 23, 2015 09:54
[ANSYS Meshing] Meshing cuboidal room with openings nickdaish ANSYS Meshing & Geometry 6 February 21, 2015 11:17
[ANSYS Meshing] Meshing strategy for External Flows Hybrid ANSYS Meshing & Geometry 0 January 24, 2012 14:27
Urgent help, help pl for meshing problem Shashi FLUENT 8 October 8, 2008 11:24
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
