[ICEM] ICEM meshing
Like Tree1Likes
  • 1 Post By Daniel_Khazaei
Old   May 11, 2014, 16:15
Default ICEM meshing
Ali reza
1988 is on a distinguished road
hello
I am completely amateur in ICEM
I have imported a geometry with .stl format which is like a curved pipe to ICEM and I don't know how to mesh and define boundary conditions, PLEASE help me .It shows that it is just one surface but I need to have 3 boundary conditions for inlet,outlet and wall and I am looking for good mesh and boundaries.
if there any one who can help?
1988 is offline   Reply With Quote
Old   May 12, 2014, 05:29
SanS
sans is on a distinguished road
I don't think anyone would have the time to list down the entire procedure. Have you completed a few tutorials in ICEM?
sans is offline   Reply With Quote
Old   May 12, 2014, 05:37
Ali reza
thanks for your attention
you are absolutely right but I am in a big rush and I just need important few steps to do that because I am using Gambit and in this case somehow it is not capable .
I have seen some tutorials about ICEM on the web but non of them was relevant to my geometry If you know any tutorial please share it.
thank you
Old   May 12, 2014, 08:45
Daniel
Daniel_Khazaei will become famous soon enough
thank you
Have you ever checked ICEM CFD Tutorial Manual?
It has a tutorial called "Tetra/Prism Mesh Generation for an Aorta" which is close to what you need.
Tetra/Prism Mesh Generation is the easiest method which you can learn by going through that tutorial.
Best wishes
D. Khazaei
1988 likes this.
Daniel_Khazaei is offline   Reply With Quote
Old   May 12, 2014, 15:54
Ali reza
It is really helpful
thanks for your help and support
regards
Complex .stl data for volume meshing in ICEM CFD Nils_H ANSYS Meshing & Geometry 5 September 2, 2011 08:39
Meshing a Mixing Plane in ICEM Will Anderson ANSYS Meshing & Geometry 2 November 9, 2010 09:16
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 17:08
[ICEM] ICEM meshing problem xyq102296 ANSYS Meshing & Geometry 6 October 28, 2010 10:09
ICEM meshing question gsbhatia89 ANSYS Meshing & Geometry 5 June 14, 2010 08:24
