May 7, 2014, 05:58 |
Association in ICEM
Rep Power: 14 |
Hi
If I got a cube as a geometry and I created a block, is association a compulsory step for this geometry? I think we only need to edit the edge parameters, right? Thanks for your explanation |
May 7, 2014, 06:30 |
Javi
Rep Power: 16 |
Hi Ke Wu,
If you want avoid problems when you read your mesh in a solver, you should associate edge to curve. |
May 7, 2014, 09:47 |
Rep Power: 14 |
May 12, 2014, 17:09 |
Sebastian Engel
Rep Power: 20 |
By associating edges boundary elements (e.g. line and quadrilateral elements) will be created while premeshing. Most solver probably need seperate sets of boundary elements.
I think that for a 3d block geometry the association of the corner points with the vertices might be enough, too. |
May 13, 2014, 04:07 |
#5 | |
Rep Power: 14 |
I checked the mesh in Fluent, no error turned up |
Edges association in ICEM | Santiago Orrego. | CFX | 10 | July 26, 2020 11:45 |
Edge association in ICEM CFD for compressor flow passage- Need help! | supermanks | ANSYS | 1 | February 19, 2014 00:39 |
[ICEM] Different meshes from ICEM and GAMBIT | Mojtaba.a | ANSYS Meshing & Geometry | 9 | March 30, 2013 02:42 |
[ICEM] Meshing adjacent wall geometry and simple ICEM questions | everdimension | ANSYS Meshing & Geometry | 25 | June 20, 2012 04:25 |
Design Modeler to ICEM..... | Joe | CFX | 0 | January 24, 2008 03:39 |
