[ICEM] Skewness Quality after using Mid Side Nodes Functionality
Old   July 13, 2014, 23:06
Default Skewness Quality after using Mid Side Nodes Functionality
Daniel
Daniel_Khazaei will become famous soon enough
Hello to all,
I am using ICEM to create a mesh for Ansys Structural. I want to have SOLID186 (quadratic element) elements instead of the default SOLID185 (linear element) elements. In order to do that, I have used mid side node functionality in convert mesh type tab.
The output is O.K. and the mesh does seem normal. However, when I check Skewness quality in ICEM, I have so many low Skewness elements.
Skewness quality was O.K before adding mid side nodes.
Can ICEM calculate Skewness on quadratic elements?
Is it even relevant to check that after adding mid side nodes?
Best wishes
Daniel_Khazaei is offline   Reply With Quote
[ANSYS Meshing] Mesh export with mid side nodes SGA ANSYS Meshing & Geometry 4 September 21, 2012 00:04
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
[Commercial meshers] Converting meshes that includes interfaces ham OpenFOAM Meshing & Mesh Conversion 29 January 8, 2007 08:58
