[Workbench] Parametrization of geometry, mesh and fluent |
July 18, 2014, 05:55 |
Although many of you know very well how to parametrize the geometry and simulation in workbench (Part I and III below), but miss the point that is how to parametrize the hexa meshing in ICEM CFD. Please note you can easily parameterize very simple hexa mesh. Also defining prism settings and parameters, surface mesh parameters, global mesh parameter etc are easily parameterized and can be updated using update function.
But the problem lies in the parameterization of blocking in ICEM which is explained in part II https://www.youtube.com/watch?v=zNA6...ature=youtu.be https://www.youtube.com/watch?v=egtU...ature=youtu.be https://www.youtube.com/watch?v=9gBW...ature=youtu.be |
July 20, 2014, 06:25 |
Javi
Rep Power: 16 |
Thank you very much for your videos Far!!
February 2, 2018, 00:49 |
Shubham Deshmukh
Rep Power: 10 |
Thanks Far for the tutorials, but is it possible to parametrize mesh for turbomachinery applications where the parameter for change is blade twist angles?
Won't there be a necessity to provide a new framework for blocking as the twist angles have changed greatly? Thanks, Shubham_SD |
[ICEM] Create geometry (iges or step file) from fluent mesh | muketa | ANSYS Meshing & Geometry | 10 | August 5, 2015 05:38 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
[ICEM] Missing face error from FLUENT even after repairing mesh + other questions | unknown159 | ANSYS Meshing & Geometry | 0 | July 5, 2013 20:18 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
