[GAMBIT] Curved Tube Using a Two Phase Approach
Old   August 21, 2014, 10:06
CR-7
Heat Pipe is on a distinguished road
This pic explains my inquiry
Is there any need to delete the yellow path line after getting the Geometry ??
Heat Pipe is offline   Reply With Quote
Old   August 22, 2014, 00:36
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
you can delete it
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   August 22, 2014, 04:54
CR-7
Oky Max I really appreciate your effort
Take a look at the last work of mine. After deleting the path line was Oky
Now the last issue is how to mesh it
I did meshing to the volume directly and selected Hex(elements) with Map(type) but I need to achieve the following
48X48X200 as a X*Y*Z
Old   August 22, 2014, 05:04
-mAx-'s Avatar
Maxime Perelli
if you need to mesh also the inner part of your domain, you won't be able to mesh it with quad (I already mentionned it at the beginning of your thread).
For your request 48x48x200. mesh the section (2d) first with desired mesh density and finally mesh the volume by giving the density along one curved edge (200 nodes for instance)
Old   August 22, 2014, 05:19
CR-7
Yes I remembered your point.
Let discuss this ... in my picture I think the inner wall is meshed as presented in the pic but after doing mesh check I got that message as mentioned in the black line with the picture which is :
0 out of 1 meshed volume failed mesh check for inverted elements !!!
Old   August 22, 2014, 05:23
-mAx-'s Avatar
Maxime Perelli
try to split your geometry symetrically along (yz), and remesh just one half.
Check if this problem remains
Old   August 22, 2014, 05:50
CR-7
After splitting my geometry by a plane (YZ)
To mesh it I got a Prompt then my Gambit and later the program does not continue
Old   August 22, 2014, 06:10
-mAx-'s Avatar
Maxime Perelli
split along (xz) befor splitting along (yz)
Old   August 22, 2014, 06:19
CR-7
Still the same !!!!
Old   August 22, 2014, 06:28
-mAx-'s Avatar
Maxime Perelli
but you didn't split it...
like this:
Old   August 22, 2014, 06:34
CR-7
I did and this the step before delete the another half
Old   August 22, 2014, 06:38
-mAx-'s Avatar
Maxime Perelli
upload your dbs on a share server, I will look at it
Old   August 22, 2014, 07:00
CR-7
http://speedy.sh/v6SAQ/max.dbs
Go through it
Old   August 22, 2014, 07:13
-mAx-'s Avatar
Maxime Perelli
no problem from my side to mesh it on the fly
*mesh Face.4 with size 1
*mesh volume.1 with size 1
>> worst element 0.2
Old   August 22, 2014, 09:30
CR-7
Same procedure of your
the summarizing gave this
0 out of 1 meshed volume failed mesh check for skewed elements > 0.97
Old   August 22, 2014, 09:35
-mAx-'s Avatar
Maxime Perelli
check skewness of surface mesh (2d)
Old   August 22, 2014, 09:55
CR-7
3D
Total elements = 69300
Active elements = 69300 100%
lower = 0
upper = 1
Worst element 0.199768
2D
Old   August 22, 2014, 10:00
-mAx-'s Avatar
Maxime Perelli
Originally Posted by Heat Pipe View Post
3D
lower = 0
upper = 1
That's what I get.
If you get this, than volume meshing is successful
Old   August 22, 2014, 10:05
CR-7
Thanks mate
I meshed the volume directly without meshing the face 4 as you did
got 0.202 the worst element only
is it correct ?
Cheers
Old   August 22, 2014, 10:06
-mAx-'s Avatar
Maxime Perelli
I understand right now what you did....
You used the Check Volume Meshes, which gives you " 0 out of 1 meshed volume failed mesh check for ...", which means that no volume has failed the check mesh.
Then all volumes have successful check mesh
HLL Riemann Shock Tube Matlab Problem Luke F Main CFD Forum 2 May 20, 2016 02:10
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
What is best mesh for cylinder tube? olivia FLUENT 7 January 16, 2014 05:55
How can I model nanofluids with single and 2 phase approach ? safikhani_hamed CFX 3 August 3, 2011 06:35
Statistical Approach for Lagrangian Two Phase Model Hesham El-Batsh Main CFD Forum 0 November 20, 1998 09:20
