[ICEM] Problem of meshing bundle of wired hollow cylinders
Old   September 9, 2014, 05:59
Default Problem of meshing bundle of wired hollow cylinders
Qing FAN
fanq is on a distinguished road
Hello everyone here,
The simulation I want to do is that, there are a bundle of wired hollow pins, and I want to know the velocity and pressure fields around one pin, and maybe thermal field around it later. And I build a hexagonal prism area by using ICEM CFD, the problem is that, when I rebuild the topology, the geometry is ruined. And I have changed the tolerance of build topology, it still doesn't work. If I do not rebuild topology, meshing fails.
Could anybody give me some suggestions on rebuilding topology or the simulation? Thanks.
fanq is offline   Reply With Quote
[ICEM] Meshing problem in Formula one Far ANSYS Meshing & Geometry 113 April 23, 2013 12:36
[ICEM] problem with meshing in icem cfd saurabhjoshi2011 ANSYS Meshing & Geometry 13 March 12, 2013 11:27
[ICEM] Tetra meshing problem Smaras ANSYS Meshing & Geometry 4 February 21, 2013 09:04
[ICEM] ICEM meshing problem xyq102296 ANSYS Meshing & Geometry 6 October 28, 2010 10:09
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 09:22
