[ICEM] Misorientation of volume elements
Old   September 15, 2014, 08:43
Default Misorientation of volume elements
Ali
Ali3031 is on a distinguished road
Hey guys,
I'm having an issue with ICEM. Whenever I rotate a 2d mesh into a 3d using rotating block feature, I always get the message misorientation of volume elements. When I click on fix, it does appear to fix the issue, but on closer look, when I export the mesh to fluent, the cells close to the axis of rotation appear very skewed. I was wondering how to prevent such an issue ? If you guys have any ideas plz let me know. I have even tried a simple geometry such as a rectangle which is rotated into a cylinder but I have obtained similar problems.
Cheers
Ali
Ali3031 is offline   Reply With Quote
975 problem volume elements were found for Uncovered faces syler3321 ANSYS Meshing & Geometry 0 October 23, 2011 03:41
[Commercial meshers] CuBit t42 OpenFOAM Meshing & Mesh Conversion 6 July 10, 2008 07:51
help: the volume mesh has highly skewed elements xiaofish FLUENT 3 September 18, 2007 09:51
how to avoid zero volume elements sameer CFX 1 February 2, 2006 19:10
