[DesignModeler] Why my geometry appear as 3D? |
October 23, 2014, 16:47 |
Rep Power: 16 |
Hello I am tried to draw 2D geometry in xy-plane I open designModeler and draw a rectangle in xy-plane and give its dimension as 1m*1m after I press extrude then generate the geometry become as 3D? what the problem may somebody guide me?
mariam |
October 24, 2014, 02:28 |
That is exactly what the extrude feature is supposed to do.
Check out "Concept > Surfaces from Sketches" |
October 24, 2014, 04:22 |
Rep Power: 16 |
I plotted the rectangle then select concept>surfaces from sketches then after press extrude an error appear: undefined base object? is there something wrong i did?
October 27, 2014, 10:04 |
Amin
Rep Power: 14 |
[ICEM] Volume Meshing Problem; YOUR GEOMETRY HAS A HOLE | mariachi | ANSYS Meshing & Geometry | 5 | May 30, 2018 02:52 |
Question about Geometry vs. Meshes | EphemeralMemory | ANSYS Meshing & Geometry | 2 | December 8, 2016 13:02 |
Running CFD parallel. There is no geometry file! | CrashLaker | SU2 | 6 | April 10, 2014 03:08 |
[CAD formats] translating geometry from Abaqus to OpenFOAM | skuznet | OpenFOAM Meshing & Mesh Conversion | 3 | January 10, 2014 13:49 |
[GAMBIT] import terrain geometry | cfdworker | ANSYS Meshing & Geometry | 2 | May 24, 2009 21:40 |
