[ICEM] Holes in fan-blades
Old   December 2, 2014, 17:25
Red face Holes in fan-blades
Chris_321's Avatar
Christian
Chris_321 is on a distinguished road
How can i close holes like this? And why are they there?
If I just mesh the surfaces there are no holes...
How is it possible in Icem to connect a fluid and a surface mesh?
Solved : Just click "keep Parts" in the Fluid computation
Chris_321 is offline   Reply With Quote
Old   December 2, 2014, 19:34
Default adjust Edge criterion
jyh
jyh3134 is on a distinguished road
The holes exist probably due to thin trailing edge.
You should reduce Edge criterion(Global Mesh Setup - Volume mesh parameters)
According to ICEM-CFD Help,
"Edge criterion determines to waht extent a tetra is cut to represent geometry. The entered value is a factor of the tetra edge."
Try reducing edge parameter to 0.01(default is 0.2).
or you can define 'thin cuts'.
To use 'thin cuts', you have to define three separate parts at least (upper surface, lower surface, curves between them).
For more information, refer to ICEM CFD Help.
jyh3134 is offline   Reply With Quote
Rotating blades of a fan by Fluent? guillaume1990 FLUENT 17 June 22, 2016 03:01
Rotating blades of a fan Fluent? guillaume1990 ANSYS 1 March 21, 2014 03:15
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 08:24
fan driven flow, Fan BC validation (getting lost) soonic OpenFOAM Running, Solving & CFD 0 July 7, 2013 19:16
axial flow in counter rotating ducted fan Vishu FLUENT 4 January 13, 2004 17:52
